ello,
I am actually evaluating the latest trial version of the Android set, the grid look full of feature on the code side but i can't figure out some basic UI features.
One of them is regarding the sort feature:
If i set a sort programmatically, how can i display an icon on the sorted column header to indicate the status and order to the user ?- i understand the the control provide the capability to sort on several columns, and make the UI thing trickier, however let's assume a simple case with only one column sorted -
Thanks !
Edit : based on this blog post it seems possible, hower i can't read about on the doc or found the properties on the code, must i create a Templatecolumn from scratch to implement the UI sorting arrows ?
https://dzone.com/articles/infragistics-android-161
Our samples browser demonstrates the implementation of the sorting indicators. I'm working on getting providing this to you and will update you tomorrow.
Hello Michael,
Wow thanks, i must admit that i didn't noticed at all the sample browser (quite well hidden in public documents) !I'v got it, i will look at the sample now, please consider this case as close.
Thanks,Jean
Jean,
Great! In case you need the location the default location for the samples is located at the logged in user's documents folder.
C:\Users\[user]\Documents/Infragistics
Let me know if you have any questions regarding this matter.
