185
WebHierarchicalDataGrid template field link button
I'm using the WebHierarchicalDataGrid with a template field that has a linkbutton; when the grid loads for some users the link button text will be "edit" and for some "view". I already have the change in the text for the parent rows working using the InitializeRow and findcontrol on the row.
I can't figure out how to get child row linkbutton text to change from edit to view depending on my user criteria.
Please see the print screen; the links in the parent (circled in blue) I have working.
I need help with the child links (circled in red).
Thanks for your help, Pat
  • 2535
    Hi Pat,
    In the WebHierarchicalDataGrid the event InitializeRow is fired for all the rows(in the child and parent grid).
    You can extend you logic and add a check for the row level. For example:
    protected void WebHierarchicalDataGrid1_InitializeRow(object sender, RowEventArgs e)
            if(((ContainerGridRecord)e.Row).Level == 0)
                // Add logic for changing template text for parent
            if (((ContainerGridRecord)e.Row).Level == 1)
                // Add logic for changing template text for child grid
    Let me know if I may be of further assistance.
