i am Using WHDG, for Parent and Child Relationship. My Checkboxes are Disabled as i didn't want to Disabled them . Here is My Code:
<ig:WebHierarchicalDataGrid ID="WebHierarchicalDataGrid1" runat="server" AutoGenerateBands="False" AutoGenerateColumns="False" DataKeyFields="id" DataMember="Module" EnableAjax="False" InitialExpandDepth="-1" InitialDataBindDepth="-1" Height="350px" Width="900px"> <Columns> <ig:BoundDataField DataFieldName="id" Hidden="true" DataType="System.Int32" Key="id" Width="100px"> <Header Text="Module ID" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Item" DataType="System.String" Key="Item"> <Header Text="Module Description" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Data" Hidden="true" DataType="System.String" Key="Data"> <Header Text="Operations" /> </ig:BoundDataField> <ig:BoundCheckBoxField DataFieldName="View" DataType="System.Boolean" Key="View"> <Header Text="View" /> </ig:BoundCheckBoxField> <ig:BoundCheckBoxField DataFieldName="Update" DataType="System.Boolean" Key="Update"> <Header Text="Update" /> </ig:BoundCheckBoxField> <ig:BoundCheckBoxField DataFieldName="Delete" DataType="System.Boolean" Key="Delete"> <Header Text="Delete" /> </ig:BoundCheckBoxField> <ig:BoundCheckBoxField DataFieldName="Save" DataType="System.Boolean" Key="Save"> <Header Text="Save" /> </ig:BoundCheckBoxField> </Columns> <Bands> <ig:Band AutoGenerateColumns="False" DataKeyFields="Item" DataMember="TRN_CODE" Key="ChildBand_0"> <Columns> <ig:BoundDataField DataFieldName="id" Hidden="true" DataType="System.Int32" Key="idCh"> <Header Text="Child ID" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Item" DataType="System.String" Key="ItemCh"> <Header Text="Child Item" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Data" Hidden="true" DataType="System.String" Key="DataCh"> <Header Text="Child Data" /> </ig:BoundDataField> <ig:BoundCheckBoxField DataFieldName="ChView" DataType="System.Boolean" Key="ChView"> <Header Text="View" /> </ig:BoundCheckBoxField> <ig:BoundCheckBoxField DataFieldName="ChUpdate" DataType="System.Boolean" Key="ChUpdate"> <Header Text="Update" /> </ig:BoundCheckBoxField> <ig:BoundCheckBoxField DataFieldName="ChDelete" DataType="System.Boolean" Key="ChDelete"> <Header Text="Delete" /> </ig:BoundCheckBoxField> <ig:BoundCheckBoxField DataFieldName="ChSave" DataType="System.Boolean" Key="ChSave"> <Header Text="Save" /> </ig:BoundCheckBoxField>
</Columns> <Behaviors> </Behaviors> </ig:Band> </Bands> <Behaviors> <ig:Selection CellClickAction="Row" CellSelectType="None" RowSelectType="Single"> </ig:Selection> <ig:Activation> </ig:Activation> </Behaviors> </ig:WebHierarchicalDataGrid>
In order to change the states of the checkboxes, the CellEditing behavior has to be enabled.
<Behaviors> <ig:Selection CellClickAction="Row" CellSelectType="None" RowSelectType="Single"> </ig:Selection> <ig:Activation> </ig:Activation> <ig:EditingCore EnableInheritance="true"> <Behaviors> <ig:CellEditing EnableInheritance="true"> </ig:CellEditing> </Behaviors> </ig:EditingCore> </Behaviors>
I have attached a small sample for your reference. Please test it on your side and let me know whether it helps you achieve your requirement.
18264.Sample.zip
