i am working on WebHirarchicalDataGrid and i want to Create the CheckBoxes Dynamically as i want to set Each CheckBox a unique ID.i have Columns the set on Server Side , i want the Same on CheckBox Also.i want to Create BoundCheckBox Field code on code behind. My Front and BackEnd Code is :
<ig:WebHierarchicalDataGrid ID="WebHierarchicalDataGrid1" runat="server" AutoGenerateBands="False" AutoGenerateColumns="False" DataKeyFields="id" DataMember="Module" EnableViewState="true" ViewStateMode="Enabled" StyleSetName="Office2007Blue" InitialExpandDepth="3" InitialDataBindDepth="3" Height="350px" Width="900px" > <%--<ClientEvents Initialize="InitializHandler" Click="ClickHandler"/>--%> <%-- <AutoPostBackFlags RowSelectionChanged="false" />--%> <%--<AutoPostBackFlags CellSelectionChanged="Of" />--%> <Columns> <ig:BoundDataField DataFieldName="id" Hidden="true" DataType="System.Int32" Key="id" Width="100px"> <Header Text="Module ID" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Item" DataType="System.String" Key="Item"> <Header Text="Module Description" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Data" Hidden="true" DataType="System.String" Key="Data"> <Header Text="Operations" /> </ig:BoundDataField> <%--<ig:BoundCheckBoxField DataFieldName="View" DataType="System.Boolean" Key="View"> <Header Text="View" /> </ig:BoundCheckBoxField> <ig:BoundCheckBoxField DataFieldName="Update" DataType="System.Boolean" Key="Update"> <Header Text="Update" /> </ig:BoundCheckBoxField> <ig:BoundCheckBoxField DataFieldName="Delete" DataType="System.Boolean" Key="Delete"> <Header Text="Delete" /> </ig:BoundCheckBoxField> <ig:BoundCheckBoxField DataFieldName="Save" DataType="System.Boolean" Key="Save"> <Header Text="Save" /> </ig:BoundCheckBoxField>--%> </Columns> <Bands> <%--<ig:Band AutoGenerateColumns="False" DataKeyFields="Item" DataMember="TRN_CODE" Key="ChildBand_0">--%> <ig:Band AutoGenerateColumns="False" DataKeyFields="ChildId" DataMember="TRN_CODE" Key="ChildBand_0"> <Columns> <%-- <ig:BoundDataField DataFieldName="ChildTableId" Hidden="false" DataType="System.Int32" Key="ChildTableId"> <Header Text="ChildTableId" /> </ig:BoundDataField>--%> <ig:BoundDataField DataFieldName="ChildId" Hidden="true" DataType="System.Int32" Key="DataCh"> <Header Text="Child Id" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Item" DataType="System.String" Key="ItemCh"> <Header Text="Child Item" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="ParentId" Hidden="true" DataType="System.Int32" Key="idCh"> <Header Text="Parent ID" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Operations" Hidden="false" DataType="System.String" Key="Operations"> <Header Text="Operations" /> </ig:BoundDataField> <ig:BoundCheckBoxField DataFieldName="Trn_Operations" DataType="System.Boolean" Key="Trn_Operations" > <%--<Header Text="Operations" />--%> </ig:BoundCheckBoxField> <%--<ig:BoundCheckBoxField DataFieldName="ChView" DataType="System.Boolean" Key="ChView"> <Header Text="View" /> </ig:BoundCheckBoxField> <ig:BoundCheckBoxField DataFieldName="ChUpdate" DataType="System.Boolean" Key="ChUpdate"> <Header Text="Update" /> </ig:BoundCheckBoxField> <ig:BoundCheckBoxField DataFieldName="ChDelete" DataType="System.Boolean" Key="ChDelete"> <Header Text="Delete" /> </ig:BoundCheckBoxField> <ig:BoundCheckBoxField DataFieldName="ChSave" DataType="System.Boolean" Key="ChSave"> <Header Text="Save" /> </ig:BoundCheckBoxField>--%>
</Columns> <Behaviors> <ig:EditingCore BatchUpdating="True"> <Behaviors> <ig:RowAdding/> <ig:RowDeleting/> <ig:CellEditing/> </Behaviors> </ig:EditingCore> <%--<ig:EditingCore AutoCRUD="false"> <Behaviors> <ig:CellEditing> <ColumnSettings> <ig:EditingColumnSetting ColumnKey="ItemCh" ReadOnly="true" /> </ColumnSettings> </ig:CellEditing> </Behaviors> </ig:EditingCore>--%> </Behaviors> </ig:Band> </Bands>
<Behaviors>
<ig:Selection CellClickAction="Row" CellSelectType="None" RowSelectType="Single"> <AutoPostBackFlags CellSelectionChanged="false" RowSelectionChanged="false" ColumnSelectionChanged="false" /> <%--<AutoPostBackFlags RowSelectionChanged="false" />--%>
</ig:Selection> <ig:Activation> </ig:Activation> <ig:EditingCore BatchUpdating="True"> </ig:EditingCore> <%--<ig:EditingCore> <Behaviors>
<ig:CellEditing> <ColumnSettings> <ig:EditingColumnSetting ColumnKey="Item" ReadOnly="true" /> </ColumnSettings> </ig:CellEditing> </Behaviors> </ig:EditingCore>--%> </Behaviors> </ig:WebHierarchicalDataGrid>
and code Behind Code is;
private DataTable CreateGridDataSourceForSubModules(string tableName, bool duplicate) {
DataTable SubModules = Trn_Oprations.GetAllTrnsList(); // Create a new DataTable. System.Data.DataTable table = new DataTable(tableName); // Declare variables for DataColumn and DataRow objects. DataColumn column; DataRow row;
// Create new DataColumn, set DataType, // Create First column. //column = new DataColumn(); //column.DataType = System.Type.GetType("System.Int32"); ////column.ColumnName = "Data"; //column.ColumnName = "ChildTableId"; //column.AutoIncrement = false; //column.Caption = "ChildTableId"; //column.ReadOnly = false; //column.Unique = false; //// Add the column to the table. //table.Columns.Add(column);
column = new DataColumn(); column.DataType = System.Type.GetType("System.Int32"); //column.ColumnName = "Data"; column.ColumnName = "ChildId"; column.AutoIncrement = false; column.Caption = "ChildId"; column.ReadOnly = false; column.Unique = false; // Add the column to the table. table.Columns.Add(column);
// Create second column. column = new DataColumn(); column.DataType = System.Type.GetType("System.String"); column.ColumnName = "Item"; column.AutoIncrement = false; column.Caption = "Item"; column.ReadOnly = false; column.Unique = false; // Add the column to the table. table.Columns.Add(column); // ColumnName and add to DataTable. column = new DataColumn(); column.DataType = System.Type.GetType("System.Int32"); column.ColumnName = "ParentId"; column.ReadOnly = true; // Add the Column to the DataColumnCollection. table.Columns.Add(column);
column = new DataColumn(); column.DataType = System.Type.GetType("System.String"); column.ColumnName = "Operations"; //column.DefaultValue = false; table.Columns.Add(column);
column = new DataColumn(); column.DataType = System.Type.GetType("System.Boolean"); column.ColumnName = "Trn_Operations"; table.Columns.Add(column);
//TemplateDataField templateCol = new TemplateDataField(); //templateCol.ItemTemplate = new CustomItemTemplate(); //WebHierarchicalDataGrid1.Columns.Add(templateCol); //column = new DataColumn(); //column.DataType = System.Type.GetType("System.Boolean"); //column.ColumnName = "ChView"; //column.AutoIncrement = false; //column.Caption = "View"; ////column.ReadOnly = false; //column.Unique = false; //column.DefaultValue = false; //// Add the column to the table. //table.Columns.Add(column);
//column = new DataColumn(); //column.DataType = System.Type.GetType("System.Boolean"); //column.ColumnName = "ChUpdate"; //column.AutoIncrement = false; ////column.Caption = "Update"; //column.ReadOnly = false; //column.Unique = false; //column.DefaultValue = false; //// Add the column to the table. //table.Columns.Add(column);
//column = new DataColumn(); //column.DataType = System.Type.GetType("System.Boolean"); //column.ColumnName = "ChDelete"; //column.AutoIncrement = false; //column.Caption = "Delete"; //// column.ReadOnly = false; //column.Unique = false; //column.DefaultValue = false; //// Add the column to the table. //table.Columns.Add(column);
//column = new DataColumn(); //column.DataType = System.Type.GetType("System.Boolean"); //column.ColumnName = "ChSave"; //column.AutoIncrement = false; //column.Caption = "Save"; //column.ReadOnly = false; //column.Unique = false; //column.DefaultValue = false; //// Add the column to the table. //table.Columns.Add(column);
//for (int j = 0; j < SubModules.Rows.Count; j++) //{ // string Trn_id = SubModules.Rows[j]["Trn_Id"].ToString(); // DataTable GetTrnOperationsByTrnId = Trn_Oprations.GetOperationsByTrn(Trn_id);
//for (int u = 0; u < GetTrnOperationsByTrnId.Rows.Count; u++) //{ // BoundCheckBoxField field = new BoundCheckBoxField(true); // column = new DataColumn(); // field.Key = "Discontinued" + u + 1; // field.Header.Text = "Discontinued" + u; // field.DataFieldName = "Discontinued" + u; // this.WebHierarchicalDataGrid1. // this.WebHierarchicalDataGrid1.Columns.Add(field); // // column.Columns.Add(field); //} // }
// Make the ID column the primary key column. if (!duplicate) { DataColumn[] PrimaryKeyColumns = new DataColumn[1]; PrimaryKeyColumns[0] = table.Columns["id"]; table.PrimaryKey = PrimaryKeyColumns; } else {
//DataColumn[] PrimaryKeyColumns = new DataColumn[1]; //PrimaryKeyColumns[0] = table.Columns["ChildTableId"]; //table.PrimaryKey = PrimaryKeyColumns; }
for (int k = 0; k < SubModules.Rows.Count; k++) { string TrnId = SubModules.Rows[k]["Trn_Id"].ToString(); DataTable TrnOperations=Trn_Oprations.GetOperationsByTrn(TrnId);
for (int j = 0; j < TrnOperations.Rows.Count; j++) // it Should Create Each by the count of Trn Operations { row = table.NewRow(); // CheckBox cb = new CheckBox(); string a = SubModules.Rows[k]["MODULE_CODE"].ToString(); // row["ChildTableId"] = k; row["ParentId"] = Convert.ToInt32(a); row["Item"] = SubModules.Rows[k]["Menu_Label"].ToString(); row["ChildId"] = Convert.ToInt32(SubModules.Rows[k]["Trn_Id"].ToString()); // BoundCheckBoxField ckField = new BoundCheckBoxField(); // ckField.Key = TrnOperations.Rows[j]["Opr_Description"].ToString(); row["Operations"] = TrnOperations.Rows[j]["Opr_Description"].ToString(); //((BoundCheckBoxField)this.WebHierarchicalDataGrid1.Columns["Operations"]).ValueConverter = ; string OperationName= TrnOperations.Rows[j]["Opr_Description"].ToString(); table.Rows.Add(row);
return table;
Hello Muhammad,
After investigating this further, I determined that a BoundCheckboxField for the “Save” column of the dataSource could be defined in a method bound to the “OnInit“ event as follows:
BoundCheckBoxField saveColumn = new BoundCheckBoxField();
saveColumn.Key = "Save";
saveColumn.Header.Text = "Save";
saveColumn.DataFieldName = "Save";
saveColumn.Hidden = false;
WebHierarchicalDataGrid1.GridView.Columns.Add(saveColumn);
Additionally a column could be added to one of the bands the following way:
saveColumn.Key = "ChSave";
saveColumn.DataFieldName = "ChSave";
WebHierarchicalDataGrid1.Bands["ChildBand_0"].Columns.Add(saveColumn);
A checkbox could be added by defining a TemplateDataField in the method bound to the “OnInit” and adding the checkbox as ItemTemplate:
private class CheckboxTemplate : ITemplate
#region ITemplate Members
public void InstantiateIn(Control container)
CheckBox checkbox = new CheckBox();
checkbox.ID = "checkbox";
container.Controls.Add(checkbox);
#endregion
protected void WebHierarchicalDataGrid1_Init(object sender, EventArgs e)
TemplateDataField checkboxColumn = new TemplateDataField();
checkboxColumn.Key = "CheckBox";
checkboxColumn.ItemTemplate = new CheckboxTemplate();
WebHierarchicalDataGrid1.GridView.Columns.Add(checkboxColumn);
Furthermore, the id of the checkbox could be set in a method bound to the “OnInitializeRow” event:
protected static int id = 0;
protected void WebHierarchicalDataGrid1_InitializeRow(object sender, RowEventArgs e)
if (e.Row.Items.FindItemByKey("CheckBox") != null && e.Row.Items.FindItemByKey("CheckBox").FindControl("checkbox") != null)
e.Row.Items.FindItemByKey("CheckBox").FindControl("checkbox").ID += id;
id += 1;
Below I am attaching a sample, demonstrating the described behavior. Please test it on your side and let me know if you need any further information regarding this matter.
Monika Kirkova,
WebHierarchicalDataGridAddColumnsServerSide.zip
