245
Read DropDown ValueField in WebDataGrid Cell
I am migrating from old UltraWinGrid (10.2) to WebDataGrid (20.1.20201.24) but I  having problem on how to proceed.
My project Grids have frequently many Columns with WebCombo inside and each one has a visible "Text" and a hidden "Value" (both string).
I would need to get the "Value" set by  user, when saving page, by reading the Grid update with a loop on "rows" and "columns" and read a Cells (server side in C # code) to write them in a recordset.
The DropDown value obtained, once saved on the recordset, in a new Grid DataBind, should load the DropDown displaying the relative Text.
This procedure worked with old UltraWebGrids.
CmbValueField = Grid.Rows[Rig].Items[Col].Value.ToString();  (Value sample)
CmbTextField = Grid.Rows[Rig].Items[Col].Text;   (Text sample)
Instead, using the WebDataGrid and setting the Grid Column as "BoundDataField" (string) and adding an editor DropDownEditorProvider I can only obtain by code the displayed Text of the DropDown.
By making a different selection on the DropDown and reading the new "Value" server side, I always get the value loaded at the first Grid databind: all user changes are ignored.
How can I proceed to get the correct "value"?
This is my Grid:
<ig:WebDataGrid ID="Grid" runat="server" AutoGenerateColumns="False"
                EnableDataViewState="True" EnableRelativeLayout="True" BorderWidth="0px"
                Height="435px" Width="745px">
                <Columns>
                    <ig:BoundDataField DataFieldName="KKK" DataType="System.Int32" Hidden="True" HtmlEncode="False" Key="KKK" Width="20px">
                        <Header Text="KKK" />
                    </ig:BoundDataField>
                    <ig:BoundDataField DataFieldName="X99V" DataType="System.Int32" Hidden="True" HtmlEncode="False" Key="X99V" Width="20px">
                        <Header Text="X99V" />
                    <ig:BoundDataField DataFieldName="KC02" DataType="System.String" HtmlEncode="False" Key="KC02" Width="40px">
                        <Header Text="KC02" />
                    <ig:BoundDataField DataFieldName="C02Y" DataType="System.String" HtmlEncode="False" Key="C02Y" Width="200px">
                        <Header Text="C02Y" />
                    <ig:BoundDataField DataFieldName="C02Z" DataType="System.String" HtmlEncode="False" Key="C02Z" Width="200px">
                        <Header Text="C02Z" />
                    <ig:BoundDataField DataFieldName="WC01" HtmlEncode="True" Key="WC01"  Width="140px" DataType="System.String">
                        <Header Text="WC01" />
                    <ig:UnboundCheckBoxField HeaderChecked="False" Key="Del" HeaderCheckBoxMode="Off" Width="20px" CssClass="igg_CheckBoxAlignCentrer">
                    </ig:UnboundCheckBoxField>
                </Columns>
                <EditorProviders>
                    <ig:TextEditorProvider ID="Grid_TextEditor_KC02">
                        <EditorControl ID="EditorControl1" runat="server" CssClass="igg_EditCell">
                        </EditorControl>
                    </ig:TextEditorProvider>
                    <ig:TextEditorProvider ID="Grid_TextEditor_C02Y">
                        <EditorControl ID="EditorControl2" runat="server" CssClass="igg_EditCell">
                        </EditorControl>
                    <ig:TextEditorProvider ID="Grid_TextEditor_C02Z">
                        <EditorControl ID="EditorControl3" runat="server" CssClass="igg_EditCell">
                        </EditorControl>
                    <ig:DropDownProvider ID="Grid_Cmb_WC01" StretchHeight="True" >
                        <EditorControl ID="EditorControl4" runat="server" CssClass="igdd_GTComboInGrid" DropDownOffsetX="3"
                                       TextField="Valore" ValueField="Chiave" ClientIDMode="Predictable">
                            <Button DisabledImageUrl="../../Images/Combo/Style1/btn_comboGrid_disabled.gif"
                                HoverImageUrl="../../Images/Combo/Style1/btn_comboGrid_normal.gif"
                                PressedImageUrl="../../Images/Combo/Style1/btn_comboGrid_pressed.gif" />
                            <DropDownItemBinding TextField="Valore" ValueField="Chiave"></DropDownItemBinding>
                        </EditorControl>
                    </ig:DropDownProvider>
                </EditorProviders>
                <Behaviors>
                    <ig:Activation>
                    </ig:Activation>
                    <ig:EditingCore AutoCRUD="False" BatchUpdating="True">
                        <Behaviors>
                            <ig:CellEditing>
                                <ColumnSettings>
                                    <ig:EditingColumnSetting ColumnKey="KC02" EditorID="Grid_TextEditor_KC02" ReadOnly="True" />
                                    <ig:EditingColumnSetting ColumnKey="C02Y" EditorID="Grid_TextEditor_C02Y" />
                                    <ig:EditingColumnSetting ColumnKey="C02Z" EditorID="Grid_TextEditor_C02Z" />
                                    <ig:EditingColumnSetting ColumnKey="WC01" EditorID="Grid_Cmb_WC01" />
                                </ColumnSettings>
                                <EditModeActions MouseClick="Single" />
                            </ig:CellEditing>
                            <ig:RowAdding>
                                <ColumnSettings>
                                    <ig:RowAddingColumnSetting ColumnKey="KC02" EditorID="Grid_TextEditor_KC02" />
                                    <ig:RowAddingColumnSetting ColumnKey="C02Y" EditorID="Grid_TextEditor_C02Y" />
                                    <ig:RowAddingColumnSetting ColumnKey="C02Z" EditorID="Grid_TextEditor_C02Z" />
                                    <ig:RowAddingColumnSetting ColumnKey="WC01" EditorID="Grid_Cmb_WC01" />
                                </ColumnSettings>
                            </ig:RowAdding>
                        </Behaviors>
                    </ig:EditingCore>
                    <ig:RowSelectors>
                    </ig:RowSelectors>
                </Behaviors>
            </ig:WebDataGrid>
Thanks in advance.
