I am coding a Web app in vb.net 2005. I have an ultraWebGrid and ultraWebCalcManager on a aspx page. The grid displays several rows and columns of data correctly. However, the calcManager does not seem to work. When the program reaches the line with sum([Column Name]) I receive the error message that the name 'Sum' is not declared. Here are portions of the code from the code behind:Imports Infragistics.WebUI.UltraWebGridImports Infragistics.WebUI.UltraWebCalcManager......... Private Sub dgPermMkdnDtl_InitializeLayout(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.LayoutEventArgs) Handles dgPermMkdnDtl.InitializeLayout Dim calcManager As Infragistics.WebUI.UltraWebCalcManager.UltraWebCalcManager calcManager = New Infragistics.WebUI.UltraWebCalcManager.UltraWebCalcManager() e.Layout.Grid.CalcManager = calcManager........ Dim colorsBand As New UltraGridBand Dim detailsBand As New UltraGridBand........ dgPermMkdnDtl.Bands.Add(colorsBand) dgPermMkdnDtl.Bands.Add(detailsBand) detailsBand.Columns.Add("MarkdownNo", "MarkdownNo")........ detailsBand.Columns.FromKey("MarkdownNo").Footer.Total = SummaryInfo.Formula detailsBand.Columns.FromKey("MarkdownNo").Footer.Formula = "SUM([MarkdownNo])"........Do you have any examples to share or any suggestion?Thanks.Glenn
