Normal 0 false false false RU X-NONE X-NONE
I have edited WebDataGrid localization issue. My Page.OnInit sets the current culture as follows:
System.Threading.Thread.CurrentThread.CurrentCulture = CultureInfo.CreateSpecificCulture("de-DE");
DateTime and Numeric values are displayed OK:
13.02.2000 81796,50
16.12.2007 232995,00
22.06.2005 1340,00
09.09.2009 23456,50
Then I edit those values. After exit from editing mode WebDataGrid displays the edited values ignoring localization settings:
13/02/2000 81796.50
The way of current culture setting makes no matter. For example, the following code leads to the same result:
System.Threading.Thread.CurrentThread.CurrentCulture = CultureInfo.GetCultureInfo("de-DE");
I use the standard WebDateChooserProvider and WebNumericEditProvider
Explicit assigning WebDateChooserProvider.Culture and WebNumericEditProvider.Culture makes no matter too
thanks
Problem resolved. This was issue with out master pages overriding culture after InitilizeCulture() methods ran.
Once that was fixed, IG controls and grid worked fine.
Forgot to page scriptmanager:
<ig13:WebScriptManager id="sm" runat="server" EnableScriptGlobalization="true" EnableScriptLocalization="true"></ig13:WebScriptManager>
I have it set up as you mentioned in this thread, but my webdatagrid ignores all globalization settings,
I have my webscirptmanager as:
and for my code behind:
protected override void InitializeCulture() { string cultureCode = IFContext.UserPreferences.Settings.Culture; cultureCode = "hi-IN"; //this is overridden and hard coded for test reason //below is read-only so have to use CreateSpecificCultre instead //this.Culture = cultureCode; //this.UICulture = cultureCode; System.Globalization.CultureInfo cultr = System.Globalization.CultureInfo.CreateSpecificCulture(cultureCode); System.Globalization.CultureInfo cultUI = System.Globalization.CultureInfo.CreateSpecificCulture(cultureCode); cultr.NumberFormat.CurrencySymbol = string.Empty; cultUI.NumberFormat.CurrencySymbol = string.Empty; System.Threading.Thread.CurrentThread.CurrentCulture = cultr; System.Threading.Thread.CurrentThread.CurrentUICulture = cultUI; base.InitializeCulture(); }
for IG fields I set culcture as:
fldCFTotal.Culture = CultureInfo.CurrentUICulture;
For lablels I use format as:
lbl_BS_BMV.Text = String.Format(CultureInfo.CurrentUICulture, "{0:C}", ds.Tables[0].Rows[0]["Market_Value"]);
The all the fields work, but webdatagrid does not show any globalized formatting for currency, numbers or dates. For example I still see currency symbol in the grid columns but not in the fields.
The columns have dataformat properties set up as DataFormatString="{0:C}". What am I missing?
No, everything should work off of the ScriptManager. If you can post a small example of what you are doing we can review it here. Thanks.
@Alex Kartavov:
I tried what you said and it did not work for me. I have the WebDataGrid inside an UpdatePanel so I do not know if this can be the be reason.
Does the WebDatasGrid have any property to set the culture info?
Thans a lot
