Hi,i have some columns predefined in my code:<ig:BoundDataField DataFieldName="State" Key="State" Width="150px" > <Header Text="Status" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Ok" Key="Ok" Width="30px" > <Header Text="OK" /> </ig:BoundDataField>When i try to DataBilnd a DataTable with the following columns:DataColumn ColumnUsed = new DataColumn("State", typeof(System.String)); TableLicData.Columns.Add(ColumnUsed);DataColumn ColumnOk = new DataColumn("Ok", typeof(System.String)); TableLicData.Columns.Add(ColumnOk); the WebDataGrid shows all the columns twice like this:State | Ok | State | Oki need the design time predefinition otherwise the column objects do not exist server side.So how to DataBind without double the column numbers?
Most probably you have AutoGenerateColumns turned-on, setting it to false should fix the issue.
