165
WebHierarchicalDataGrid gives a NullReferenceException
I use an WebHierarchicalDataGrid with a WebHierarchicalDataSource and 3 ObjectDataSources (3 levels of data). I get the following error most of the time. I am using an evalation version.
Does anyone have the same problem? Is there any workarround?
 [NullReferenceException: De objectverwijzing is niet op een exemplaar van een object ingesteld.]
   Infragistics.Web.UI.Framework.AppStyling.StyleBot.ImageDirectoryResolved() +48
   Infragistics.Web.UI.Framework.AppStyling.StyleBot.ResolveImageUrl(String imageUrl, Boolean useCache) +347
   Infragistics.Web.UI.Framework.AppStyling.StyleBot.ResolveImageUrl(String imageUrl) +39
   Infragistics.Web.UI.Framework.ImageObject.ResolveImageUrl(String url, String defaultUrl) +100
   Infragistics.Web.UI.Framework.ImageObject.GetRenderImageUrl() +60
   Infragistics.Web.UI.Framework.ImageObject.Render(HtmlTextWriter writer) +225
   Infragistics.Web.UI.GridControls.GridBehaviorsImageButton.Render(HtmlTextWriter writer) +71
   Infragistics.Web.UI.GridControls.HierarchicalGridRenderer.SetupButton(ContainerGrid grid, Boolean collapsed) +430
   Infragistics.Web.UI.GridControls.HierarchicalGridRenderer.BehaviorEvents_BeforeRecordItemsXslRender(Object sender, RenderingRowSelectorXslEventArgs e) +1205
   Infragistics.Web.UI.GridControls.GridBehaviorEvents.OnBeforeRecordItemsXslRender(XmlTextWriter writer, String cssClass, String expansionColumnCss) +113
   Infragistics.Web.UI.GridControls.GridRenderer.RecordMatch() +780
   Infragistics.Web.UI.GridControls.GridRenderer.RecordMatchContent() +44
   Infragistics.Web.UI.GridControls.GridRenderer.Frame() +494
   Infragistics.Web.UI.GridControls.GridRenderer.GenerateXsl() +205
   Infragistics.Web.UI.GridControls.GridRenderer.RenderContents(HtmlTextWriter writer) +1049
   Infragistics.Web.UI.GridControls.ContainerGridRenderer.RenderContents(HtmlTextWriter writer) +258
   Infragistics.Web.UI.Framework.RunBot.HandleRenderContents(HtmlTextWriter writer, RendererBase renderer) +134
   Infragistics.Web.UI.GridControls.WebDataGrid.GetRenderHTML() +178
   Infragistics.Web.UI.GridControls.ContainerGrid.Infragistics.Web.UI.GridControls.IXPathDataNavigableObject.get_Xml() +266
   Infragistics.Web.UI.GridControls.XPathDataNavigable.GetFirstChild() +43
   Infragistics.Web.UI.GridControls.XPathDataNavigator.MoveToFirstChild() +122
   Infragistics.Web.UI.GridControls.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) +286
   Infragistics.Web.UI.GridControls.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) +317
   Infragistics.Web.UI.GridControls.XPathDataNavigator.get_OuterXml() +199
   Infragistics.Web.UI.GridControls.GridRenderer.RenderContents(HtmlTextWriter writer) +1236
   Infragistics.Web.UI.GridControls.HierarchicalGridRenderer.RenderContents(HtmlTextWriter writer) +608
   Infragistics.Web.UI.Framework.Data.HierarchicalDataBoundControlMain.RenderContents(HtmlTextWriter writer) +70
   Infragistics.Web.UI.Framework.Data.HierarchicalDataBoundControlMain.Render(HtmlTextWriter writer) +39
   System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27
   System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +99
   System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25
   System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +134
   System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +19
   System.Web.UI.Control.Render(HtmlTextWriter writer) +10
   System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) +163
   System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) +32
   System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) +51
   System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) +40
   System.Web.UI.Page.Render(HtmlTextWriter writer) +29
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1266
