Is there a way to align a column on the right and not align the filter row to the right. We need to have numeric columns aligned to the right side however doing so also alters the filterrow to the point where it is not usable. When the filter is on the right the edit cell is the width of the cursor so you can't see what is being entered. I have tried to overide the filter row and force it back to the left but nothing seems to work. Has anyone else ran into this issue or know of solutions?
I am also facing the same issue. but the solution provided did not work. Still the filter icon comes right aligned with the data in the grid column. Please suggest
Are you using a different style set or IE 6? If its a different style, simply change the class name to include the style set name. If you're on IE 6, you'll need to get rid of the '>' in the definition, so just .igg_FilterRow td { }
regards,David Young
