425
Issue with ITemplate Button in WebDataGrid 2010.3
The grid that I’m using inherits the Infragistics.Web.UI.GridControls.WebDataGrid. The version of Infragistics is 2010 volume 3.
 I want to create an ITemplate for my inherited WebDataGrid which contains a button. I add a click event on this button and the button displays itself very well on the WebDataGrid. When I click on a button in the grid it generates a postback and that's where my issue begins.
I'd selected one row and clicked on the button but when I debug my codebehind during the postback it states: "Behaviors.Selection.SelectedRows" have a count of 0. It seems that when I click the button on my inherited WebDataGrid it looses the selected rows collection.
The template looks like this:
public class Cx_DatagridTemplateButton : ITemplate
    Button _oButton;
    /// <summary>
    ///     Delegate event method click
    /// </summary>
    public delegate void click();
    /// <summary>
    ///     This is the instance of the deligate method. These instance will run if we click on the button
    /// </summary>
    public click ClickEvent;
    /// <summary>
    ///     Wen a datarow is initialized
    /// </summary>
    /// <param name="container"></param>
    public virtual void InstantiateIn(Control container)
        this._oButton = new Button();
        this._oButton.ID = "btnButton";
        this._oButton.Width = Unit.Percentage(100);
        this._oButton.Height = Unit.Percentage(100);
        this._oButton.Click += delegate(object dlgSender, EventArgs dlgE)
            this.ClickEvent();
        container.Controls.Add(_oButton);
With the following manner I add the button column to the WebDataGrid (when there is no postback):
Cx_DatagridTemplateButton template = new Cx_DatagridTemplateButton();
Infragistics.Web.UI.GridControls.TemplateDataField column = new Infragistics.Web.UI.GridControls.TemplateDataField();
column.Header.Text = "Button";
column.ItemTemplate = template;
column.Key = "tempCol";
column.Width = System.Web.UI.WebControls.Unit.Pixel(60);
this.Cx_Datagrid1.Columns.Add(column);
this.Cx_Datagrid1.DataBind();
template.ClickEvent += new Cx_DatagridTemplateButton.click(_Default_Click);
Session.Add("tempCol", template);
When there is a postback:
((Infragistics.Web.UI.GridControls.TemplateDataField)this.Cx_Datagrid1.Columns[0]).ItemTemplate = (Cx_DatagridTemplateButton)Session["tempCol"];
The problem I  had before this issue was the fact that my button disappeared when the page had a postback. Therefore I enclosed the template in a session object to retrieve it again when the postback is handled.
The method I use for (_Default_Click) looks like:
public void _Default_Click()
System.Diagnostics.Debug.WriteLine("Selected rows: " + Cx_Datagrid1.Behaviors.Selection.SelectedRows.Count);
When I debug this code, I get the total count of the selectedrows is 0.
If I put it in my page_load the selected rows are 0 also.
The strange thing is when I place a click event on a different control on my page which generates a postback then the code DOES display the selected rows as it should be.
How can I resolve this that I can use the ITemplate Button on my inherited WebDataGrid so I can access the selected rows on the codebehind (server) when a button is clicked.
Thanks for answering
