hello I used a new version Infragistics35.Web.v11.1, Version=11.1.20111.2036
But after upgrade the control WebDropDown result a ScriptRessource error.
I use autofiltrering client side.
my code :
this error appears when i write a caract which is not in result in my
datasource.
error :
Thanks & Regard's Philippe
Thanks & Regard's
Philippe
Hello everyone,
There has been an internal issue created and resolved about what you are experiencing. As far as I am aware there is a service release coming out at the end of this week. Please get it as soon as it comes out and the issue you're experiencing would go away. Thank you for your patience and we're sorry for the inconvenience caused!
Thank you for using the Infragistics forums!
Hi everyone,
Petar, we can't modify your "check" because the script is in ScriptRessource's Infargistics !
I uninstalled the last release build ( version 2064)
Greets
I have the same error, Please I need a answer to solve that!
My error is when there aren't matches in the list items, with autofiltering= client.
I'm facing the same problem! I have version 11.1.20111.2064. But when I write something in the webdropdown that doesn't exists on the datasource, it gives that error. Could you please provide some help??
Hi Phillipe,
I am following up to check whether you are still experiencing any issues. Please do not hesistate to contact me if you have any questions.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://www.infragistics.com/support
