65
WebDataGrid
HI Guys,
    I am using the webdatagrid version 2011.2,  We use the entityframework as our datalayer and I am having issues with the paging.
I use an entityDataSource control on the page to access the framework.  It appears that the webdatagrid doesnt support paging via an entitydatasource?
If i use the standard datagrid (microsofts) with the entitydatasource then the paging is lightning fast, if i use the same entitydatasource with the webdatagrid then it just hangs - the table behind the entitydatasource contains 600,000 records.  I have enabled the paging behaviour but i suspect it is trying to load all 600k records?
Should this work?
What am I doing wrong?
