40
Use web dialog window to update a record
Hii;
I want to update record in my webdatagrid using webdialogwindow with textboxes in it can you please suggest me how can i do it. Post that you have posted earlier is good but can you please suggest me some other way i can do it .I am attaching my code please help me
function PromptEdit(sControlID){
oWebDialogWindow1 = $find(sControlID);
oWebDialogWindow1.set_windowState($IG.DialogWindowState.Normal);
function Confirm() {
oWebDialogWindow1.set_windowState($IG.DialogWindowState.Hidden);
function Cancel() {
function DeleteRow() {
var grid = $find('<%= WebDataGrid1.ClientID %>');
var gridRows = grid.get_rows()
var selectedRows = grid.get_behaviors().get_selection().get_selectedRows();
var rows = new Array();
var i1 = 0;
for (var i = selectedRows.get_length() - 1; i >= 0; i--) {
rows[i1] = selectedRows.getItem(i);
i1++;
grid.get_behaviors().get_editingCore().get_behaviors().get_rowDeleting().deleteRows(rows);
</script>
<style type="text/css">
.igg_ActiveCell
color: white;
background-image: url("ig_res/Default/images/Activebg.gif");
</style>
</asp:Content>
<asp:Content ID="BodyContent" runat="server" ContentPlaceHolderID="MainContent">
<asp:HiddenField ID="hdnID" runat="server" />
<div id="wrapper" class="wgDataBind">
<asp:ScriptManager ID="scriptManager1" runat="server">
</asp:ScriptManager>
<div id="container">
<%-- <div id="headerContainer" class="ControlPanelHeader">
<img alt="Configuration" src="ig_res/Default/images/config.png" />
Control Panel
</div>--%>
<%-- <div id="countContainer" class="controlPanel">
<div id="eventList" class="controlPanelEvent">
<asp:CheckBox ID="ActivationOn" Text="ActivationOn:" AutoPostBack="true" Checked="true"
runat="server" TextAlign="Left" OnCheckedChanged="ActivationOn_CheckedChanged" />
</div>--%>
<div id="DataGridWrapper">
<ig:WebDataGrid ID="WebDataGrid1" runat="server" Height="350px" Width="400px" AutoGenerateColumns="false"
AutoCRUD="True" DefaultColumnWidth="100px" DataKeyFields="ID" OnRowAdded="WebDataGrid1_RowAdded">
<AjaxIndicator Enabled="False" />
<Columns>
<ig:TemplateDataField Key="DeleteItem" Width="60px">
<ItemTemplate>
<asp:ImageButton runat="server" ID="DeleteItem" AlternateText="DeleteButton" ImageUrl="~/ig_res/Default/images/DeleteIcon_en.PNG"
OnClientClick="DeleteRow(); return false;" />
</ItemTemplate>
</ig:TemplateDataField>
<ig:TemplateDataField Key="EditItem" Width="60px">
<ItemTemplate>
<img onclick="PromptEdit('<%= WebDialogWindow1.ClientID %>')"
src="ig_res/Default/images/button_edit.png" alt="edit" width="70" height="23" />
</ItemTemplate>
<ig:BoundDataField Header-Text="ID" DataFieldName="ID" Key="ID">
</ig:BoundDataField>
<ig:BoundDataField Header-Text="FirstName" DataFieldName="FirstName" Key="FirstName">
<ig:BoundDataField Header-Text="LastName" DataFieldName="LastName" Key="LastName">
<ig:BoundDataField Header-Text="City" DataFieldName="City" Key="City">
<ig:BoundDataField Header-Text="Country" DataFieldName="Country" Key="Country">
</Columns>
<%-- <Behaviors>
<ig:Filtering Alignment="Top" Visibility="Visible" Enabled="True" FilterType="ExcelStyleFilter"
<ColumnSettings>
<ig:ColumnFilteringSetting ColumnKey="City" Enabled="False" />
</ColumnSettings>
</ig:Filtering>
<ig:Paging PagerAppearance="Bottom" PageSize="10" Enabled="true" />
<ig:Activation ActiveCellCssClass="igg_ActiveCell" Enabled="true" />
</Behaviors>--%>
<Behaviors>
<ig:Selection RowSelectType="Single" Enabled="true" CellClickAction="Row" />
<ig:Paging PagerAppearance="Bottom" PageSize="6" Enabled="true" />
<ig:RowSelectors Enabled="true" RowNumbering="true" />
<ig:Sorting SortingMode="Single" Enabled="true" />
<ig:ColumnMoving Enabled="true" />
<ig:ColumnResizing Enabled="true" />
<ig:EditingCore>
<Behaviors>
<%-- <ig:RowEditing EditModeActions-EnableF2="true" EditModeActions-MouseClick="Single"
Enabled="true">
<ColumnSettings>
<ig:EditingColumnSetting ColumnKey="ID" ReadOnly="true" />
</ColumnSettings>
</ig:RowEditing>--%>
<ig:RowAdding Alignment="Top" EditModeActions-EnableF2="true" EditModeActions-EnableOnActive="true"
EditModeActions-MouseClick="Single" Enabled="true" />
<ig:RowDeleting Enabled="true">
</ig:RowDeleting>
</Behaviors>
</ig:EditingCore>
<ig:ColumnFixing ShowLeftSeparator="true" ShowRightSeparator="true" AutoAdjustCells="true">
<ColumnSettings>
<ig:ColumnFixingSetting FixButtonAlignment="Left" ColumnKey="FirstName" EnableFixing="True"
FixLocation="Left" />
</ColumnSettings>
</ig:ColumnFixing>
<ig:Filtering Alignment="Top" Visibility="Visible" Enabled="true" AnimationEnabled="True" />
<ig:SummaryRow Enabled="true" />
</Behaviors>
<EditorProviders>
<ig:TextEditorProvider ID="WebTextEditProvider1" />
</EditorProviders>
</ig:WebDataGrid>
<div id="Div1" class="dwConfirmationDialog">
<%-- <div id="ResetButton">
<img onclick="PromptEdit('<%= WebDialogWindow1.ClientID %>')" src="ig_res/Default/images/button_edit.png"
alt="edit" width="87"
height="23" /></div>--%>
<ig:WebDialogWindow runat="server" ID="WebDialogWindow1" InitialLocation="Centered"
DataKeyField="ID" Height="150px" Width="286px" Modal="true" WindowState="Hidden"
Style="line-height: normal" >
<Header CaptionAlignment="Left" CaptionText="Update Data Here">
<CloseBox Visible="False" />
</Header>
<ContentPane BackColor="White">
<Template>
<asp:Label ID="lblFirstName" runat="server" Text='FirstName:'></asp:Label>
<asp:TextBox ID="txtFirstName" runat="server" Style="margin-left: 1px" Text='<%#Eval("FirstName") %>'></asp:TextBox><br />
<asp:Label ID="lblLastName" runat="server" Text='LastName:'></asp:Label>
<asp:TextBox ID="txtLastName" runat="server" Style="margin-left: 1px" Text='<%#Eval("LastName") %>'></asp:TextBox>
<br />
<asp:Label ID="lblCity" runat="server" Text='City:'></asp:Label>
<asp:TextBox ID="txtCity" runat="server" Style="margin-left: 31px" Text='<%#Eval("city") %>'></asp:TextBox>
<br />
<asp:Label ID="lblCountry" runat="server" Text='Country:'></asp:Label>
<asp:TextBox ID="txtCountry" runat="server" Style="margin-left: 12px" Text='<%#Eval("Country") %>'></asp:TextBox>
<br />
<div style="position: absolute; right: 5px; top: 120px; height: 23px">
<img onclick="Confirm()" style="cursor: hand;" src="ig_res/Default/images/button_save.png"
alt="Update" width="43" height="23" />
<img onclick="Cancel()" style="cursor: hand;" src="ig_res/Default/images/button_cancel.png"
alt="Cancel" width="43" height="23" />
</div>
</div>
</Template>
</ContentPane>
</ig:WebDialogWindow>
</div>
</div>
</div>
</div>
<asp:SqlDataSource ID="srcEmployees" ConnectionString="Data Source=.\SQLEXPRESS;AttachDbFilename=|DataDirectory|MyData.mdf;Integrated Security=True;User Instance=True"
SelectCommand="SELECT ID,FirstName,LastName,City,Country FROM EmployeeDetails"
InsertCommand="Insert into EmployeeDetails(FirstName,LastName,city,country) values (@FirstName,@LastName,@city,@country)"
DeleteCommand="Delete From EmployeeDetails where ID=@ID" UpdateCommand="Update EmployeeDetails set FirstName=@FirstName,LastName=@LastName,city=@city,country=@country where ID=@ID"
runat="server"></asp:SqlDataSource>
</asp:Content>
