45
Not able to load the WebDialogWindow in IE 7,8,0
Hi ,
I am using an infragistics WebDialogWindow control.  I facing strange issues with respect to WebDialogWindow  control.  Its working  as expected on some machine while giving issue while loading on some client machines.
Following are  the errors which i am receiving.
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; .NET4.0C; InfoPath.2; .NET4.0E)
Timestamp: Mon, 15 Sep 2014 07:02:15 UTC
Message: '$IG.ControlObjectProps.Count' is null or not an object
Message: Sys.ArgumentUndefinedException: Value cannot be undefined.Parameter name: baseType
Particularly on the line
$IG.LayoutPaneProps = new function()
var count = $IG.ControlObjectProps.Count;
this.ScrollLeft = [count++, 0];
this.ScrollTop = [count++, 0];
this.ScrollBars = [count++, 1];
this.Count = count;
/******************************************END LayoutPaneProps ENUM********************************/
/******************************************ContentPaneProps ENUM************************************/
$IG.ContentPaneProps = new function()
var count = $IG.LayoutPaneProps.Count;
this.ContentUrl = [count++, ''];
this.Count = count;
Followig is the code block which i am using.
<asp:UpdatePanel ID="WebDialogsUpdatePanel" runat="server" ChildrenAsTriggers="true" UpdateMode="Conditional">
<ContentTemplate>
<ig:WebDialogWindow runat="server" ID="SessionExplorerWebDialogWindow"
Height="600px" Width="600px" Modal="true" WindowState="Hidden" CssClass="SessionExplorerWebDialogWindow"
Moveable="true" Resizer-Enabled="true" Top="200px" Left="220px" InitialLocation="Centered">
<Header CloseBox-Visible="false" CaptionText="Session Explorer" Font-Size="12pt">
<CloseBox Visible="true"></CloseBox>
</Header>
<ContentPane>
<Template>
<br />
<uc2:SessionExplorer ID="CustodySessionExplorer" runat="server" />
<br />
<div class="DocumentGenerationButtonAlign">
<asp:UpdateProgress ID="UpdateProgress5" runat="server" AssociatedUpdatePanelID="WebDialogsUpdatePanel" DynamicLayout="false" >
<ProgressTemplate>
<div id ="ProgressDisplay1" style="display:inline">
<asp:Image ImageAlign="Middle" ID="Imageloader" runat="server" ImageUrl="~/Images/Whiteboard/ajax-loaderW.gif" />
</div>
</ProgressTemplate>
</asp:UpdateProgress>
</div>
<div class = "WebDialogCloseButtonPosition">
<asp:Button ID="SessionExplorerCloseButton" runat="server" Text="Close" onclick="SessionExplorerCloseDialogButton_Click"
CausesValidation="false"/>&nbsp;&nbsp;</div>
</Template>
</ContentPane>
</ig:WebDialogWindow>
</ContentTemplate>
<Triggers>
<asp:AsyncPostBackTrigger ControlID="SessionExplorerImageButton" EventName="click" />
</Triggers>
</asp:UpdatePanel>
