I am converting Infragistics 2010 v2 CLR3.5 to Infragistics 2014 v2 using 4.5 CLR using Visual Studio 2013 Professional Update 4. I am getting following error while building the project. Please reply immediately..........
Error 230 'System.Web.UI.WebControls.PageEventArgs' does not contain a definition for 'NewPageIndex' and no extension method 'NewPageIndex' accepting a first argument of type 'System.Web.UI.WebControls.PageEventArgs' could be found (are you missing a using directive or an assembly reference?)
Below error is there while fixing the code:
private void grid_PageIndexChanged(object sender, PageEventArgs e) { int tableID, pIndex, tIndex, gridPageSize; string tableNM, DB, filterExp = "", sortExp = ""; pIndex = e.NewPageIndex; tIndex = contentTab.SelectedIndex + 1;
Hello Jack,
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
The PageEventArgs now contain only the OldPageIndex. You can get the new page index like this:
protected void WebHierarchicalDataGrid1_PageIndexChanged(object sender, PagingEventArgs e)
int pageIndex = (sender as ContainerGrid).Behaviors.Paging.PageIndex;
Let me know if I can be of further help.
