From code-behind, I am unable to set the enabled state of the button. I can see that the property is available via the properties section in the
Visual Studio, but the methods or property are not available or not visible through Intellisense.
Paul
Hello Paul,
Thank you for using our forum!
Could you please share more details about the issue because I am unable to reproduce it. Using of Enabled property should work as expected.
Useful references:
https://www.infragistics.com/community/forums/f/ultimate-ui-for-asp-net/891/how-to-enable-or-disable-in-javascript
https://forums.asp.net/t/1132693.aspx?disabling+controls+at+runtime
This is odd, I am getting this log in the errorS:
Severity Code Description Project File LineError CS0012 The type 'WebButtonBase' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics45.WebUI.Shared.v15.2, Version=15.2.20152.1028, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'. MitelMatrix C:\dev\MitelMatrix\MitelMatrix\CompatibilityView.aspx.cs 34
However, I do have that reference included in web.config.
