Using the Page_Load event page to load data in the gridin the local machine when I apply the sort in any of the column of the grid the data changes and can export exactly looks in the gridbut when I public this project in our server and I apply the sort in the grid and then export it does not export the same.
the data sorted in the grid is not exported in the same order
Hello Farhad, Thank you for posting in our forums!
When you sort the column in the grid and export it in the local machine it works fine and when you deploy it to the production sorting doesn’t appear when you export the grid that means there is some difference of environment between local machine and production machine.
To better assist you with this, please provide me with any additional information like which browser(version) you are using when you work on local machine and production machine?
Please also let me know when you deploy the project where do you refer the dlls from?
You can refer the following link to understand more about Infragistics component deployment:
http://help.infragistics.com/doc/ASPNET/2015.2/CLR4.0/?page=Web_Deploying_Your_Application.html
Hello Farhad,
On local machine when you are sorting the grid and exporting it, it works fine but when you deploy it on server sorting doesn’t appear. What is the difference between both the environment of local machine and production machine? Are you using the same browser (IE11) on local and production machine? Is there any difference in IIS?
IIS 8, IE11. see image below
I have been working with Divya on this case. She was able to run your sample and the exported data is sorted correctly. Our expectation is that the same application will behave the same on two different web servers (such as your development machine and the web server you publish to).
As such I would like to verify that the only difference is indeed your web server. To do this, please confirm all of the following:
If all of these are true, please attach the excel file that was generated from running on each server.
Let me know if you have any questions with this matter.
the answear is yes to the 3 options.
At this point when you are using the same browser, IIS and same sample on both the machine I would like to have excel files generated from both local machine and server machine. And wants to know where did you keep the dlls.Please provide the excel file that was generated from running on each server.Let me know if you have any questions with this matter.
