115
Re-sizing Images in a Report
I have seen an article on this which suggests that I should create an IText element and add the image to that while specifying a size but I have found that while I can add an image to my document section directly, if I try to use
        Dim imagetext As IText = section.AddText()
        imagetext.AddContent(image, new Size(820,840))
        section.AddImage(image)
...then my page falls over with an 'out of memory' exception every time.  I have tried to re-size the image outside of the report and then add it normally but the quality which seems fine when viewinbg the image in Paint Shop is very poor when viewing the resultant PDF.  is there anything I can do to either
Make the image fit the available width of the section
Resize the image prior to adding to the section
get around the out of memory exception if I leave it up to Infragistics
Note I am using Infragistics 12.2 as I cannot change the .NET version.
Parents
No Data
Reply
  • 2525
    Hello Chris,
    At what point in execution is the exception being thrown?
    Also note, 12.2 is no longer supported. Here is a link with more information on our product lifecycle: http://www.infragistics.com/support/product-lifecycle
Children
No Data
