Hi Team,
I am using the Infragistics version 14.2. In the version i am creating the webtab control in static design time. And creating the Content Tab Item in run time. The Tab Item are created success fully.
But in my page i am creating more then 50 contant tab item in run time. My Page is supported for multi language. So i need to change my tab direction . So i using the TabLocation . These are working good in LTR mode.
But when i change the TabLocation to RTL means i cant able to see all the tabs in Scrollable Mode in my design. I am facing many design issues based on LTR and RTL direction.
Please refer the attachment images
Please note :-
The Tab Text are dynamic. cant able to fix the width in design time
I need to show all the Tabs as same manner . If the Tab text is Big means the tab need to big. If the tag text is small means the Tab is small.
Now my design not able to show as same tab manner.
I need to show all the tabs with scrollable with LTR and RTL mode. Please help me for this issue.
Hello Prabakaran,
I followed the steps you suggested and created a sample application of WebTab with 10 ContentTabItem with version 14.2. I tried changing the tab location and did not get the same issue.
If this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back, so that I will have clear understanding of the issue.
Please let me know if I can provide any further assistance.
Hi Divya Jain,
Thanks for your replay...
I attached a sample project for your references. Please get the Attachment and test via my testing point given below.
What i exactly need means when the page is LTR Mode the High lighted Arrows are in Right side. If the page is in RTL mode means the high lighted arrow need to be in Left side.
Project file Testing point.
1) In the project file go to default.aspx file.
2) Goto Body Tag and change the LTR direction to RTL.
3) Run the Project
4) Now you see the Tabs are not showing the text in the browser. For the reason the Style width are not properly supported.
Many Project we are handled with multi language and LTR AND RTL support.
Please let me know your comments
Lookes like your attachment did not come through. would like you to reattach the sample and send me in a zip file.
Looking forward to hearing you back.
Thanks for your replay... Please get the attachment Project file.
Please refer the below image.
Thank you for providing sample application and the steps to reproduce the behavior.
I assume when you said RTL in the second step to reproduce the issue, it means “RightTop” tab Location.I noticed that in the sample you have enabled EnableAjax property which is causing the issue. Try disable the property and it will resolve the issue. Tabs will render in the browser.
Regarding the other question about changing the moving directions icons of the tabs I am discussing this behavior with the development team of the WebTab for more information.I will have more information for you when I hear back from them.
If you have any further questions or concerns with this issue, please let me know.
