1414
Displaying Schedules in a WebGrid
To All,
I have posted a question in the WebGrid section of this forum.  I tracked down the stored procedure to retrieve a Resources schedule from the Infragistics supplied tables and have modified it so that I can include multiple resources (not just one at a time) - basically, use a SQL IN clause to generate a SQL string for a call to a SQL Server.  I found the Infragistic stuff very slick - and rather open.
However, the dates are stored in Universal Time.
They are displayed in the appointments form in Local Time.
Is there a way to replicate this easily when displaying the data in an Infragistics grid?  I thought it might be a column property, but now I am thinking it might be something algorithmic hidden in the scheduler tools.
R/S,
Roger
  • 2636
    Semper Fi,
    Since you have modified the stored procedure just execute the below code in SQL then call it in your select statement
     to call below code just do something like
    SELECT
    ActivityID,
    StartDate = dbo.functionConvertUTC(startdatetimeutc)
    //SQL CODE
    CREATE FUNCTION functionConvertUTC (@UTCDate datetime)
    RETURNS datetime
    AS
    BEGIN
    DECLARE
    @LocalDate datetime
    DECLARE
    @TimeDiff int
    DECLARE @CLT datetime
    SET @LocalDate = GETDATE()
    SET @TimeDiff = DATEDIFF(hh, @UTCDate, @LocalDate)
    SET @CLT = DATEADD(hh, @TimeDiff, @UTCDate)
    RETURN @CLT
    END
