55
Row management - Web DataGrid
We are implementing the Infra grid in MVC.NET framework 4.5
i have an requirement to move the rows from first to last and inbetween same as column moving feature. Please let me know is this supported in Infra 17.1 Ultimate version (Ignite UI).
Please let me know if you need more details.
Vijay
  • 23953
    Hello Vijay,
    The Ultimate UI for ASP.NET targets WebForms and will not work in MVC context. If you're talking about Ignite UI igGrid the answer is that the igGrid doesn't support row re-arranging out of the box. You need to implement it by yourself.
    There is a tread on the subject on the forums. It's old, but you can check out the attached sample for example implementation.
    Best regards,
    Martin Pavlov
    Infragistics, Inc.
