105
Missing (18.1 Infragistics45) Styles, Scripts, images folders in solution
I am missing all the various infragistics folders in my solution. I am trying to use the WebUpload and per the example require these.
How do I find / install the various required folders?
<link type="text/css" href="/Styles/css/themes/infragistics/infragistics.theme.css" rel="stylesheet" />
<link type="text/css" href="/Styles/css/structure/infragistics.css" rel="stylesheet" />
<script type="text/javascript" src="/Scripts/jquery.min.js"></script>
<script type="text/javascript" src="/Scripts/jquery-ui.min.js"></script>
<script type="text/javascript" src="/Scripts/js/infragistics.js"></script>
  • 17070
    Hello IT Department,
    The infragistics.js file is available in your installation directory under jQuery folder. For example:
    C:\Program Files (x86)\Infragistics\2018.1\ASP.NET\jQuery\js
    The jQuery and jQuery UI are files that you have to download and afterwards put them in your Scripts folder.
    The infragistics.css file can be found in your installation directory under jQuery/css/structure folder. For example:
    C:\Program Files (x86)\Infragistics\2017.2\ASP.NET\jQuery\css\structure
    Infragistics provide different style themes. The css files for every single theme can be found under the folder named after that theme  under the themes directory. For example, if the default Infragistics theme is used its infragistics.theme.css file will be available at the following location:
    C:\Program Files (x86)\Infragistics\2017.2\ASP.NET\jQuery\css\themes\infragistics
    If, for example, the ios theme is used its Infragistics.theme.css file will be available at the following location:
    C:\Program Files (x86)\Infragistics\2017.2\ASP.NET\jQuery\css\themes\ios
    Please let me know if you need any further assistance with this matter.
