Could someone provide the code for the Customizable Header example in the below page?
https://www.infragistics.com/products/aspnet/interactions/dialog-window
Thanks in advance!
Hello Yovanny,
Thank you for contacting the Infragistics support!
I think you are looking for the sample that demonstrates how to enable the WebDialogWindow’s buttons inside the header - https://www.infragistics.com/samples/aspnet/dialog-window/configuring-the-header
If you need something else, do not hesitate to contact us again with more information on what you are trying to show inside the header.
Thank you once more for using Infragistics ASP.NET!
I was looking for the code for Customizable Header example. Exactly that or very similar. The Infragistics website use to have the code for all these examples in the past (2 months ago). Today, only a screenshot is provided.
I am asking because I need the code for other examples as well and I would like to know if you plan to public the code for all these examples as you had in the past.
Thank you!
