50
WebHierarchicalDataGrid - Column Template is invisible after post back
Hi support team,
After a post back, the items in column template are invisible. I don't find anyway to keep it visible after post back.
Please see my example code:
1. ASPX:
<body>
<form id="form1" runat="server">
<ig:WebScriptManager ID="WebScriptManager1" runat="server">
</ig:WebScriptManager>
<ig:WebHierarchicalDataGrid ID="WebHierarchicalDataGrid1" runat="server" Height="350px" Width="400px"
EnableDataViewState="True" >
</ig:WebHierarchicalDataGrid>
<asp:Button ID="buttonTest" runat="server" Text="Test" OnClick="buttonTest_Click" />
</form>
</body>
2. .ASPX.CS
protected void Page_Load(object sender, EventArgs e)
if (!IsPostBack)
DataTable table = new DataTable();
table.Columns.Add("userid", typeof(string));
table.Columns.Add("name", typeof(string));
table.Columns.Add("city", typeof(string));
table.Rows.Add("1", "peter", "us");
table.Rows.Add("2", "john", "uk");
DataSet ds = new DataSet();
ds.Tables.Add(table);
WebHierarchicalDataGrid1.AutoGenerateColumns = true;
WebHierarchicalDataGrid1.DataSource = ds;
WebHierarchicalDataGrid1.RowIslandDataBinding += new RowIslandEventHandler(WebHierarchicalDataGrid1_RowIslandDataBinding);
WebHierarchicalDataGrid1.DataBind();
private void WebHierarchicalDataGrid1_RowIslandDataBinding(object sender, RowIslandEventArgs e)
TemplateDataField field1 = new TemplateDataField();
field1.Key = "TemplateColumn1";
field1.Header.Text = "Edit";
field1.ItemTemplate = new CustomItemTemplate1();
WebHierarchicalDataGrid1.Columns.Add(field1);
public class CustomItemTemplate1 : ITemplate
public void InstantiateIn(Control container)
TextBox vText = new TextBox();
vText.Text = "test";
vText.ID = "test";
vText.EnableViewState = true;
container.Controls.Add(vText);
protected void buttonTest_Click(object sender, EventArgs e)
// do nothing
Could you please help?
Uy
  • 50
    Verified Answer
    Hi all,
    I found the way to fix it. Please see the sample code.
                if (!IsPostBack)
                else {
                    Infragistics.Web.UI.GridControls.TemplateDataField x = (Infragistics.Web.UI.GridControls.TemplateDataField) WebHierarchicalDataGrid1.Columns["TemplateColumn1"];
                    x.ItemTemplate = new CustomItemTemplate1();
