20
WebDataGrid doesn't show data
       private void bindData(int startWeek, int endWeek, WebDataGrid web)
            string strSQL = string.Empty;
            DataTable objTable = new DataTable();
            string userMaker=getUserMaker(startWeek, endWeek);
            strSQL = "SELECT* FROM table ";
            objTable = new DataTable("Data");
            objTable = objAdoData.RetrieveData2Table(strSQL);
            web.ClearDataSource();
            web.ClearTemplates();
            if (objAdoData.Message.Length > 0)
                return;
            if (web.Columns.Count > 0)
                web.Columns.Clear();
            CreateWebDataGridColumns(web, objTable);
            web.DataSource = objTable;
            web.DataBind();
  protected void CreateWebDataGridColumns(WebDataGrid wdg, DataTable dt)
            wdg.ClearDataSource();
            wdg.ClearTemplates();
            wdg.Columns.Clear();
            BoundDataField BoundCol = new BoundDataField();
            BoundCol.Key = "Maker";
            BoundCol.Header.Text = "Maker";
            BoundCol.Width = 70;
            BoundCol.DataFieldName = "Maker";
            BoundCol.CssClass = "text-left";
            wdg.Columns.Add(BoundCol);
            for (int i = 1; i < dt.Columns.Count; i++)
                TemplateDataField templateCol = new TemplateDataField();
                templateCol.Key = dt.Columns[i].ColumnName;
                templateCol.Header.Text = dt.Columns[i].ColumnName;
                templateCol.Width = 100;
                templateCol.ItemTemplate = new CustomItemTemplateByLink();
                templateCol.CssClass = "text-right";
                wdg.Columns.Add(templateCol);
I have four webdatagrid  that will bind with different week data.
I use binddata() to pass week range and webdatagrid object.
And I have a dropdownlist that choose year value.
The default is current year. User can change ddl to see every year every week data.
Such as choose 2019 . He can see
bindData(1, 13, wdgData1);
bindData(14, 26, wdgData2);
bindData(27, 39, wdgData3);
bindData(40, 52, wdgData4);
_______________________________
WebDataGrid can display the right data at first time to enter the page.
But when I change the dropdownlist to see different year.
The data show null .
I make sure that the datatable has data that from database.
I don't know why  i had bind but they had not shown.
//this is ddl change method
protected void ddlYear_SelectedIndexChanged(object sender, EventArgs e)
string i = ddlYear.SelectedValue;
// this is pageload method
protected void Page_Load(object sender, EventArgs e)
if (!Page.IsPostBack)
You can see both of them is same calls.
This is first time enter. default 2019 year
When I change ddl to 2018 year , it empty
When I change back to 2019 , the original value can't show.
     <ig:WebDataGrid ID="wdgData1" runat="server" AutoGenerateColumns="false"
        StyleSetName="Default" StyleSetPath="../ig_res" Width="100%"
        <Columns>
        </Columns>
        <Behaviors>
            <ig:Activation Enabled="true" />
            <ig:ColumnResizing Enabled="false" />
            <ig:ColumnFixing ShowLeftSeparator="true" ShowFixButtons="false" />
        </Behaviors>
    </ig:WebDataGrid>
    <br />
     <ig:WebDataGrid ID="wdgData2" runat="server" AutoGenerateColumns="false"
        <Columns>
        </Columns>
        <Behaviors>
        </Behaviors>
    </ig:WebDataGrid>
    <br />
      <ig:WebDataGrid ID="wdgData3" runat="server" AutoGenerateColumns="false"
        <Columns>
        </Columns>
        <Behaviors>
        </Behaviors>
    </ig:WebDataGrid>
    <br />
    <ig:WebDataGrid ID="wdgData4" runat="server" AutoGenerateColumns="false"
        <Columns>
        </Columns>
        <Behaviors>
        </Behaviors>
    </ig:WebDataGrid>
front end code
  • 20
    Verified Answer
    Sorry, I find the reason why can't show data.
    Because I  set  WebDataGrid.Visible= True, because 2019 have not uploaded any file.
    When change to 2018, I forget to open the setting.
