Hi Team,
I have a requirement for a searchable or typeahead feature for WebDataTree, is it possible to achieve that via infragistics?
Could you share the code as well. Need to get something like below
Regards
Abraham
Hello Abraham,
Thank you for contacting the Infragistics support!
I am providing a simple example on how you may implement search functionality with the WebDataTree. In the attached sample we search by text, but you may as well search by value or key. In this example we get the address of the node that matches our search criteria.
However, hiding the nodes that do not meet the search criteria is not supported out of the box by the control and would require custom implementation. What the behavior that the attached screenshot demonstrates is more like Filtering feature.
You may refer to this thread where similar scenario is discussed - https://www.infragistics.com/community/forums/f/ultimate-ui-for-asp-net/96408/webdatatree----any-way-to-filter-nodes
Thank you once more for using Infragistics ASP.NET!
Best regards,
Alexander Marinov
WebSite90.zip
Hi Alex,
Thanks for the response. This logic you given will fetch the address index. To the minimum when I type my search keyword and click search button or on key event , cursor should highlight the node, is that possible to achieve?
Thank you for your response!
I am attaching an updated sample that demonstrates how you may highlight a node when it matches a search term. You may achieve similar behavior if you use the KeyUp client event.
Please let me know if you have any additional questions!
Best regards,Alexander
WebSite90_Updated.zip
Highlighted Node is perfect solution . But we have a completed Node structure , with this I am not able to accomplish as per your sample code.
please find my sample node
<ignav:WebDataTree ID="WebDataTree1" runat="server" Height="300px" Width="200px">
<Nodes>
<ignav:DataTreeNode Text="WorkFlow And Imaging">
<ignav:DataTreeNode Text="Domains">
<ignav:DataTreeNode Text="DOM1">
<ignav:DataTreeNode Text="Servers">
</ignav:DataTreeNode>
<ignav:DataTreeNode Text="Forms">
<ignav:DataTreeNode Text="Classes">
<ignav:DataTreeNode Text="Queries">
<ignav:DataTreeNode Text="Imports">
<ignav:DataTreeNode Text="Roles">
<ignav:DataTreeNode Text="Users">
<ignav:DataTreeNode Text="Groups">
<ignav:DataTreeNode Text="Routes">
<ignav:DataTreeNode Text="WS QueryTypes">
</Nodes>
<ignav:DataTreeNode Text="DOM2">
</ignav:WebDataTree>
and also hiding the nodes that do not meet the search criteria is a mandate requirement for us , hence I would like know more about that also. As you it is could be done via custom script. because of this feature limitation I do not want to shift to another UI control.
RegardsAbraham
I have updated the sample to demonstrate how you may search through all the tree nodes.
Also, I have provided an example on how you may hide the nodes that do not match the search clause. In addition, you may expand all nodes after this "filtering" is executed to show the users if there are filtered child nodes.
Have in mind that such functionality goes beyond the scope of the control and such implementation may lead to unexpected behaviors. However, if you think this is suitable for your scenario - you may work in this direction - hiding and showing the nodes depending on their text. Of course, you may also hide/show the expand buttons, for example.
What I would suggest is to create a product idea about Filtering feature in the WebDataTree control - https://www.infragistics.com/community/ideas/i/ultimate-ui-for-asp-net
Thank you once more for using Infragistics for ASP.NET!
Alexander
4162.WebSite90.zip
