45
Get WebGridView row from dropdownlist selectedindexchanged
okay so in a typical gridview (Microsoft ASP.net one) you can put a drop down list in a template column, then in the selectedindexchanged event you can type this
    Protected Sub ddl_PackWeek_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs)
        Dim gd_data1 As New DataAccessLayer()
        'get dropdownlist object
        Dim Myddl As DropDownList = CType(sender, DropDownList)
        'use naming container property to get the row in which the control resides
        Dim MyRow As GridViewRow = CType(Myddl.NamingContainer, GridViewRow)
'database call
        gd_data1.updatePackWeek(MyRow.Cells(0).Text, Myddl.SelectedItem.Value)
        Me.gv_receiving.DataBind()
    End Sub
How do you do this in a web grid view?
in so many words, how do I access info from the ROW of my Drop Down List?
ASP if you need it
                                         <ig:TemplateDataField Header-Text ="Pack Type" key="BoxType2" Width="200px">
                                         <ItemTemplate>
                                              <asp:DropDownList ID="DropDownList2" runat="server" AutoPostBack="True" OnSelectedIndexChanged="ddl_BoxesType2_SelectedIndexChanged"
                                                 SelectedValue='<%# Bind("BoxType2")%>' DataSourceID="sqlBoxesType2" DataTextField="BoxType2_SN" DataValueField="RecID">
                                             </asp:DropDownList>
                                         </ItemTemplat<Header Text="Pack Type"></Header>
                                         </ig:TemplateDataField>
