Hi Friends,
I have a problem in webdatagrid for fixed-column. I tried to fix columns dynamically it's not working as my expectation. Here my question is 1st and 2nd columns are manually fixed now i need to fix 3rd 4th and 5th column dynamically, So when i tried to fix 5th column it will replaced as 3rd column, but my intention is is should be in 5th place and 3rd and 4th columns need to fix automatically when i tried to fix on 5th column. Please some one help on this.
Thanks in advance!!!!
When you fix a column only the column only the column is fixed, if you want the columns before it to be fixed you have to fix them manually.
Here is a link with documentation about this behavior:
https://www.infragistics.com/help/aspnet/webdatagrid-column-fixing
