45
RowEditorTemplate- WebDropdown valuechanged need to update other webdropdowns
Hello, I have a webdatagrid with a RowEditorTemplate.
In the template, I have a WebDropDown wich will be selected by the user.
While editing, I need that the valuechanged of the WebDropdown fire an event wich will update 4 other objects (label or textfield or webdoropdown disabled, same type for all)  to update specific informations about the new value selected in the webdropDown.
I tried to use 4 webdropdown (enable = false).
I thought that this would update by coding selectedvalue=e.NewSelection but there is not effect.
They could all be binded to the same table, same id.
The event is fired, while debugging I see the values has been changed, but the description fileds are not updated in the rowEditorTemplate.
Here is the code:
Protected Sub MAJSelect(sender As Object, e As Infragistics.Web.UI.ListControls.DropDownSelectionChangedEventArgs)
On Error Resume Next
Dim ControlA
Dim ControlB
Dim ControlC
Dim ControlD
Dim CAChoisi As Integer
CAChoisi = e.NewSelection
If CAChoisi <> 0 Then
ControlA = WebDataGrid1.Behaviors.EditingCore.Behaviors.RowEditTemplate.TemplateContainer.FindControl("WDD_UniteA")
ControlB = WebDataGrid1.Behaviors.EditingCore.Behaviors.RowEditTemplate.TemplateContainer.FindControl("WDD_UniteB")
ControlC = WebDataGrid1.Behaviors.EditingCore.Behaviors.RowEditTemplate.TemplateContainer.FindControl("WDD_UniteC")
ControlD = WebDataGrid1.Behaviors.EditingCore.Behaviors.RowEditTemplate.TemplateContainer.FindControl("WDD_UniteD")
ControlA.ClearSelection
ControlB.ClearSelection
ControlC.ClearSelection
ControlD.ClearSelection
ControlA.selectedvalue = e.NewSelection
ControlB.selectedvalue = e.NewSelection
ControlC.selectedvalue = e.NewSelection
ControlD.selectedvalue = e.NewSelection
End If
End Sub
Thanks for your help!
