935
Cell Editing with WebHierarchicalDataGrid with DropdownProvider produces error.
I'm using IG 19.1 CLR4.5 with VS 2015 and IE11.
When clicking the "Cancel" button after editing a cell, I get an undefined error in dynamic JS. The error occurs if I make a selection from the DropdownProvider control or not. It does not occur if I select a value from the dropdown list and click "Done".
Below is the error message I'm receiving.
0x800a138f - JavaScript runtime error: Unable to get property 'blur' of undefined or null reference
Thank you for any help and replies.
Please include email: fxferguson@chp.org on all replies.
Thanks Again.
Here is the markup.
 <%-- Source Scripts in MasterPage--%>
<script src="Scripts/jquery-1.8.2.min.js" type="text/javascript"></script>
   <script src="Scripts/jquery-ui-1.8.24.min.js" type="text/javascript"></script>
   <script src="Scripts/jquery.tmpl.js" type="text/javascript"></script>
   <script src="Scripts/jquery.tmplPlus.js" type="text/javascript"></script>
   <script src="Scripts/jqery.tmplPlus.min.js" type="text/javascript"></script>
   <script src="Scripts/jquery-tooltip.js" type="text/javascript"></script>
   <script src="http://code.jquery.com/jquery-1.11.3.min.js" type="text/javascript"></script>
   <script src="http://code.jquery.com/ui/1.11.1/jquery-ui.min.js" type="text/javascript"></script>
   <script src="Scripts/jquery-1.4.2.tmpl.min.js" type="text/javascript"></script>
   <script src="Scripts/jquery-1.4.2.tmpl.js" type="text/javascript"></script>
   <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.7.2/jquery.min.js">
   </script>
<ig:WebHierarchicalDataGrid ID="WebHierarchicalDataGrid1" runat="server" Height="400px" DataSourceID="WebHierarchicalDataSource1" AutoGenerateBands="False" AutoGenerateColumns="False" DataKeyFields="claimtype" StyleSetName="RubberBlack" DataMember="dsClaimTypes_DefaultView" Key="dsClaimTypes_DefaultView" Width="100%">
                      <Bands>
                          <ig:Band AutoGenerateColumns="False" DataKeyFields="ClaimID" DataMember="dsClaims_DefaultView" Key="dsClaims_DefaultView" DefaultColumnWidth="200px">
                              <Columns>
                                  <ig:BoundDataField DataFieldName="claimtype" Hidden="True" Key="claimtype">
                                      <Header Text="BoundColumn_0">
                                      </Header>
                                  </ig:BoundDataField>
                                  <ig:BoundDataField DataFieldName="ClaimID" Key="ClaimID">
                                      <Header Text="ClaimID">
                                      </Header>
                                  <ig:BoundDataField DataFieldName="Provider" Key="Provider">
                                      <Header Text="Provider">
                                      </Header>
                                  <ig:BoundDataField DataFieldName="cleandate" DataType="{0:d} {0:t}" Key="cleandate">
                                      <Header Text="Clean Date">
                                      </Header>
                                  <ig:BoundDataField DataFieldName="FormType" Key="FromType">
                                      <Header Text="Form">
                                      </Header>
                                  <ig:BoundDataField DataFieldName="TotalBilled" DataFormatString="{0:c}" Key="TotalBilled">
                                      <Header Text="Billed">
                                      </Header>
                                  <ig:BoundDataField DataFieldName="ClaimWeight" Key="ClaimWeight">
                                      <Header Text="Weight">
                                      </Header>
                                  <ig:BoundDataField DataFieldName="AssignedTo" Key="AssignedTo">
                                      <Header Text="Assined To">
                                      </Header>
                              </Columns>
                              <Behaviors>
                                  <ig:EditingCore AutoCRUD="False">
                                      <EditingClientEvents CellValueChanged="WebHierarchicalDataGrid1_Editing_CellValueChanged" />
                                      <Behaviors>
                                          <ig:RowEditing>
                                              <ColumnSettings>
                                                  <ig:EditingColumnSetting ColumnKey="ClaimID" ReadOnly="True" />
                                                  <ig:EditingColumnSetting ColumnKey="Provider" ReadOnly="True" />
                                                  <ig:EditingColumnSetting ColumnKey="cleandate" ReadOnly="True" />
                                                  <ig:EditingColumnSetting ColumnKey="ClaimWeight" ReadOnly="True" />
                                                  <ig:EditingColumnSetting ColumnKey="TotalBilled" ReadOnly="True" />
                                                  <ig:EditingColumnSetting ColumnKey="FromType" ReadOnly="True" />
                                                  <ig:EditingColumnSetting ColumnKey="AssignedTo" EditorID="WebHierarchicalDataGrid1_DropDownProvider1" />
                                              </ColumnSettings>
                                          </ig:RowEditing>
                                          <ig:CellEditing>
                                              <ColumnSettings>
                                              </ColumnSettings>
                                          </ig:CellEditing>
                                      </Behaviors>
                                  </ig:EditingCore>
                                  <ig:ColumnResizing>
                                  </ig:ColumnResizing>
                                  <ig:Paging>
                                  </ig:Paging>
                              </Behaviors>
                          </ig:Band>
                      </Bands>
                      <EditorProviders>
                          <ig:DropDownProvider ID="WebHierarchicalDataGrid1_DropDownProvider1">
                              <EditorControl ClientIDMode="Predictable" DropDownContainerMaxHeight="200px" EnableAnimations="False" EnableDropDownAsChild="False" DataSourceID="dsExaminerNames" TextField="ExaminerName" ValueField="Examiner_ID" DataKeyFields="Examiner_ID" KeepFocusOnSelection="False">
                                  <DropDownItemBinding TextField="ExaminerName" ValueField="Examiner_ID" KeyField="Examiner_ID" />
                              </EditorControl>
                          </ig:DropDownProvider>
                      </EditorProviders>
                      <Columns>
                          <ig:BoundDataField DataFieldName="claimtype" Key="claimtype">
                              <Header Text="Claim Type">
                              </Header>
                          <ig:BoundDataField DataFieldName="ClaimCount" DataFormatString="{0:0,0}" Key="ClaimCount">
                              <Header Text="Claim Count">
                              </Header>
                          <ig:BoundDataField DataFieldName="WeightRange" Key="WeightRange">
                              <Header Text="Weight Range">
                              </Header>
                      </Columns>
                  </ig:WebHierarchicalDataGrid>
                      <ig:WebHierarchicalDataSource ID="WebHierarchicalDataSource1" runat="server">
                      <dataviews>
                          <ig:DataView ID="dsClaimTypes_DefaultView" DataMember="DefaultView" DataSourceID="dsClaimTypes" />
                          <ig:DataView ID="dsClaims_DefaultView" DataMember="DefaultView" DataSourceID="dsClaims" />
                      </dataviews>
                      <datarelations>
                          <ig:DataRelation ChildColumns="claimtype" ChildDataViewID="dsClaims_DefaultView" ParentColumns="claimtype" ParentDataViewID="dsClaimTypes_DefaultView" />
                      </datarelations>
                  </ig:WebHierarchicalDataSource>
                <asp:SqlDataSource ID="dsClaimTypes" runat="server" ConnectionString="<%$ ConnectionStrings:CHPCOMSDB %>" SelectCommand="usp_get_Claim_Type_Header" SelectCommandType="StoredProcedure">
                </asp:SqlDataSource>
                <asp:SqlDataSource ID="dsClaims" runat="server" ConnectionString="<%$ ConnectionStrings:CHPCOMSDB %>" SelectCommand="usp_get_Claim_Type_Detail" SelectCommandType="StoredProcedure">
<asp:SqlDataSource ID="dsExaminerNames" runat="server" ConnectionString="<%$ ConnectionStrings:CHPCOMSDB %>" SelectCommand="SELECT Examiner_ID, ExaminerName = Full_Name FROM dbo.tbl_Examiners WHERE Active = 1 ORDER BY Full_Name"></asp:SqlDataSource>
