15
On changing ViewStyleBand from Horizontal to OutlookGroupBy, I expect IsGroupByRows to set as True but this is still false. Hence GroupByRows are not visible.
I am working on two ultragrids on same view.For first grid if I change the ViewStyleBand to OutlookGroupBy , Is groupByRows is set to true, But same is not happening for the other UltraGrid.
Thanks.
  • 16310
    Hi Himanshu,
    Support for the Ultra controls has expired, therefore I can only suggest that you make sure there is no error in your code that may be changing the value of groupByRows unexpectedly for the other grid. If the issue is bug in the code, we would still not be able to fix it.
    I recommend that you try different approach to achieve the desired , if you are sure this is an issue in our product.
