I am upgrading the website to Framework 4.6.2 and from Infragistics2 Version=10.2.20102.2018 to Infragistics45 Version=19.1.20191.177.I work with Visual Studio 2017.I hope that you can help me with the WebDataGrid problem.When I pass the search value to the page the data is shown in the grid. When I change the search value and click the searchbutton the data is not shown. Everything works fine in old version of Infragistics.The aspx and vb code are below.Please let me know what else you need to see.
Thank you very much.
<%@ Page Title="Member Search Results" Language="VB" MasterPageFile="~/MPA.master" AutoEventWireup="false" CodeFile="SearchResults.aspx.vb" Inherits="Members_SearchResults" %>
<%@ MasterType TypeName="MPA" %>
<%@ Register TagPrefix="ig" Namespace="Infragistics.Web.UI.GridControls" Assembly="Infragistics45.Web.v19.1, Version=19.1.20191.177, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" %>
<%@ Register TagPrefix="igmisc" Namespace="Infragistics.WebUI.Misc" Assembly="Infragistics45.WebUI.Misc.v19.1, Version=19.1.20191.177, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" %>
<%@ Register TagPrefix="uc1" src="~/Common/ucCustomPager.ascx" tagname="ucCustomPager" %>
<asp:Content ID="Content1" ContentPlaceHolderID="head" Runat="Server"></asp:Content>
<asp:Content ID="Content2" ContentPlaceHolderID="ContentPlaceHolder1" Runat="Server">
<script type="text/javascript" language="javascript">
function clickRecall(e) {
var evt = e ? e : window.event;
var bt1 = document.getElementById('<%= cmdRecallPrev.ClientID %>');
var bt2 = document.getElementById('<%= cmdRecallPrev.ClientID %>');
// debugger;
switch (e.keyCode) {
case 38:
//alert('up');
bt1.click()
break;
case 40:
//alert('down');
bt2.click()
case 113:
// F2
bt1.click();
return false;
/* Retain element focus after UpdatePanel postback
jQuery(function($) {
var focusedElementSelector = "";
var prm = Sys.WebForms.PageRequestManager.getInstance();
prm.add_beginRequest(function(source, args) {
var fe = document.activeElement;
if (fe != null) {
if (fe.id) {
focusedElementSelector = "#" + fe.id;
} else {
// Handle Chosen Js Plugin
var $chzn = $(fe).closest('.chosen-container[id]');
if ($chzn.size() > 0) {
focusedElementSelector = '#' + $chzn.attr('id') + ' input[type=text]';
prm.add_endRequest(function(source, args) {
if (focusedElementSelector) {
$(focusedElementSelector).focus();
</script>
<div id="divContent">
<asp:UpdatePanel ID="upSearch" ChildrenAsTriggers="true" UpdateMode="Conditional" runat="server">
<ContentTemplate>
<div id="divSearchHeader" class="p1 PrintList">
<asp:Label ID="lblSearch" runat="server"
style="position:absolute; left:10px; top:20px; font-weight:bold; font-size:14px;"
Text="Enter Name, ID, or SSN:"></asp:Label>
<asp:TextBox ID="txtSearch"
CssClass="TextSearch"
runat="server"
style="position:absolute; left:210px; top:18px; width:200px;"
TabIndex="1">
</asp:TextBox>
<asp:Button ID="cmdSearch"
CssClass="btnStd"
style="position:absolute; left:430px; top:18px; width:60px; right: 476px;"
text="Search" TabIndex="2"/>
<asp:Button ID="cmdRecallNext"
style="position:absolute; left:510px; top:18px; width:0px;"
text="Recall Next"
TabIndex="3"
Visible="true"/>
<asp:Button ID="cmdRecallPrev"
text="Recall Previous"
TabIndex="4"
<asp:Label ID="lblErrorMessage" runat="server" CssClass="StdErrorMsg"
style="position:absolute; left:500px; top:20px; width:478px"></asp:Label>
<!-- added the following text box to stop the jscript runtime error when hitting the Enter button to do the search -->
<asp:TextBox ID="txtBoxFixEnterError" runat="server" style="position:absolute; left:0px; top:0px; width:10px; display:none;"></asp:TextBox>
</div> <!-- divSearchHeader -->
<div id="divSearchResults" class="p1 PrintList" style="width:100%;background:#fff5ee;">
<ig:WebDataGrid ID="wdgResults"
runat="server" Height="100%"
AutoGenerateColumns="False"
StyleSetName="Nautilus"
Width="100%"
StyleSetPath="~/ig_res/Styles_2019_1"
EnableDataViewState="false"
AjaxIndicator-ImageUrl="~/images/Loading.gif"
AjaxIndicator-Location="MiddleCenter"
AjaxIndicator-Enabled="False">
<Columns>
<ig:TemplateDataField Key="Select" Width="60px">
<Header Text="Select"/>
<ItemTemplate>
<asp:LinkButton
ID="lnkSelect"
CausesValidation="False"
CommandName="Select"
OnPreRender="addTrigger_PreRender"
OnCommand="SelectMember"
Text="Select">
</asp:LinkButton>
</ItemTemplate>
</ig:TemplateDataField>
</Columns>
<Behaviors>
<ig:Paging PageSize="12"
QuickPages="2"
PagerMode="NumericFirstLast"
PagerAppearance="Bottom"
Enabled="true">
<PagerTemplate>
<uc1:ucCustomPager ID="ucCustomPager1" runat="server"/>
</PagerTemplate>
</ig:Paging>
<ig:Selection CellClickAction="Row" CellSelectType="None"
RowSelectType="Single">
<AutoPostBackFlags RowSelectionChanged="False" />
</ig:Selection>
<ig:RowSelectors></ig:RowSelectors>
<ig:Sorting Enabled="true"
SortingMode="Single"
AscendingImageUrl="~/Images/SortAsc.gif"
DescendingImageUrl="~/Images/SortDesc.gif">
</ig:Sorting>
</Behaviors>
</ig:WebDataGrid>
</div> <!-- divSearchResults -->
</ContentTemplate>
</asp:UpdatePanel>
</div> <!-- divContent -->
</asp:Content>
Imports Infragistics.Web.UI.ListControlsImports Infragistics.Web.UI.GridControlsImports BICC.BFAS.MemberBLPartial Class Members_SearchResults Inherits System.Web.UI.Page Private marlDataRows As ArrayList Private mblMS As MemberSearch Private _customPager As ucCustomPager ' Page Protected Sub Page_Init(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Init _customPager = DirectCast(Me.wdgResults.Behaviors.Paging.PagerTemplateContainerBottom.FindControl("ucCustomPager1"), ucCustomPager) AddHandler Me._customPager.PageChanged, AddressOf _customPager_PageChanged End Sub Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load AddHandler Master.ToolbarClick, AddressOf Toolbar_Clicked MySession.CheckTimeout() ' Restore Member Search Object if it exists. If IsNothing(MySession.MemberSearchObject) Then mblMS = New MemberSearch(MySession.cnnDB, MySession.DBSchema) ' initialize member object Else mblMS = MySession.MemberSearchObject End If If Page.IsPostBack Then ' Restore Search Results marlDataRows = mblMS.SearchResults wdgResults.DataSource = marlDataRows Else InitForm() BuildGrid() Search(mblMS.SearchValue) SetPagerInfo() End If SetupRecallForPartialPostBack() Me.Page.Form.Attributes.Add("onkeydown", "javascript:return clickRecall(event);") End Sub Protected Sub Page_Error(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Error Dim ex As Exception ex = Server.GetLastError LibProcs.HandleSYSError(ex) End Sub Private Sub InitForm() Const PensionMemberSearch As String = "PENSION MEMBER SEARCH" Const PensionInquiry As String = "PENSION HISTORY INQUIRY SEARCH" Const PensionMaintenance As String = "PENSION HISTORY MAINTENANCE SEARCH" Const PensionAdj As String = "PENSION ADJUDICATION SEARCH" Dim CurrentForm As String CurrentForm = Request.ServerVariables(Constants.URL).ToString ' current page url MySession.STS_PreviousForm = MySession.STS_CallingForm MySession.STS_CallingForm = CurrentForm Select Case MySession.STS_InquiryPath Case InquiryPath.Pension Select Case MySession.GetLastFunction Case Functions.SearchMember Master.ScreenName = PensionMemberSearch Case Functions.SearchPensionHistory If MySession.STS_EditMode = Constants.EditMode Then Master.ScreenName = PensionMaintenance Else Master.ScreenName = PensionInquiry End If Case Functions.SearchAdjudication Master.ScreenName = PensionAdj End Select Case Else Master.ScreenName = PensionMemberSearch ' Default End Select BuildToolbar() txtSearch.Focus() End Sub ' Toolbar Private Sub BuildToolbar() Dim ivtoolbar As New WebImageViewer ivtoolbar.Items.Add(LibFuncs.CreateToolbarImage("~/Images/Tlbr_Back.jpg", "BUTTON1", True)) Select Case MySession.STS_InquiryPath Case InquiryPath.Pension If MySession.IsActiveFunction(Functions.SearchMember) And MySession.STS_EditMode = Constants.EditMode Then ivtoolbar.Items.Add(LibFuncs.CreateToolbarImage("~/Images/TLBR_ADD.jpg", "BUTTON2", True)) Else ivtoolbar.Items.Add(LibFuncs.CreateToolbarImage("~/Images/TLBR_Blank.jpg", "BUTTON2")) End If Case Else ivtoolbar.Items.Add(LibFuncs.CreateToolbarImage("~/Images/TLBR_Blank.jpg", "BUTTON2")) End Select ivtoolbar.Items.Add(LibFuncs.CreateToolbarImage("~/Images/TLBR_Blank.jpg", "BUTTON3")) ivtoolbar.Items.Add(LibFuncs.CreateToolbarImage("~/Images/TLBR_Blank.jpg", "BUTTON4")) ivtoolbar.Items.Add(LibFuncs.CreateToolbarImage("~/Images/TLBR_Blank.jpg", "BUTTON5")) ivtoolbar.Items.Add(LibFuncs.CreateToolbarImage("~/Images/TLBR_Blank.jpg", "BUTTON6")) ivtoolbar.Items.Add(LibFuncs.CreateToolbarImage("~/Images/TLBR_Blank.jpg", "BUTTON7")) ivtoolbar.Items.Add(LibFuncs.CreateToolbarImage("~/Images/TLBR_Blank.jpg", "BUTTON8")) ivtoolbar.Items.Add(LibFuncs.CreateToolbarImage("~/Images/TLBR_Blank.jpg", "BUTTON9")) ivtoolbar.Items.Add(LibFuncs.CreateToolbarImage("~/Images/TLBR_Blank.jpg", "BUTTON10")) Master.SetToolBar(ivtoolbar.Items) End Sub Private Sub Toolbar_Clicked(ByRef MPToolbar As WebImageViewer, ByVal ButtonPos As Integer, ByVal ButtonIdx As Integer) Select Case ButtonPos Case 1 Response.Redirect(Screens.MemberSearch, False) Case 2 ' Add Member Select Case True Case MySession.IsActiveFunction(Functions.SearchMember) MySession.BeginFunction(Functions.AddMember) Response.Redirect(Screens.MemberMaintenance, False) Case Else ' No Action End Select End Select End Sub ' Search Results Private Sub BuildGrid() Dim dgbfTemp As New Infragistics.Web.UI.GridControls.BoundDataField Dim dgcSelect As New Infragistics.Web.UI.GridControls.GridField Dim lctlSSN As New LiteralControl("SSN <img src='../Images/Sortable.gif' style='width:8px;'/>") Dim lctlEmployee As New LiteralControl("Member <img src='../Images/Sortable.gif' style='width:8px;'/>") Dim lctlMemberID As New LiteralControl("ID <img src='../Images/Sortable.gif' style='width:8px;'/>") Dim lctlCity As New LiteralControl("City <img src='../Images/Sortable.gif' style='width:8px;'/>") Dim lctlState As New LiteralControl("State <img src='../Images/Sortable.gif' style='width:8px;'/>") Dim lctlDOB As New LiteralControl("DOB <img src='../Images/Sortable.gif' style='width:8px;'/>") ' Set Grid Options wdgResults.AutoGenerateColumns = False wdgResults.Behaviors.Paging.PageSize = 13 wdgResults.Width = Unit.Percentage(100) ' Select Column 0 wdgResults.Columns("Select").Width = Unit.Pixel(50) ' SSN Column 1 With dgbfTemp .Key = "SSN" .DataFieldName = "SSN" .DataType = "System.String" .DataFormatString = "{0:000-00-0000}" .Hidden = False .Width = Unit.Pixel(90) .Header.Text = "SSN" .Header.TemplateContainer.Controls.Add(lctlSSN) End With wdgResults.Columns.Add(dgbfTemp) ' Employee Column 2 dgbfTemp = New Infragistics.Web.UI.GridControls.BoundDataField With dgbfTemp .Key = "Employee" .DataFieldName = "Employee" .DataType = "System.String" .Hidden = False .Width = Unit.Pixel(225) .Header.Text = "Member" .Header.TemplateContainer.Controls.Add(lctlEmployee) End With wdgResults.Columns.Add(dgbfTemp) ' Member ID Column 3 dgbfTemp = New Infragistics.Web.UI.GridControls.BoundDataField With dgbfTemp .Key = "MemberID" .DataFieldName = "MemberID" .DataType = "System.String" .DataFormatString = "" .Hidden = False .Width = Unit.Pixel(100) .Header.Text = "ID" .Header.TemplateContainer.Controls.Add(lctlMemberID) End With wdgResults.Columns.Add(dgbfTemp) ' City Column 4 dgbfTemp = New Infragistics.Web.UI.GridControls.BoundDataField With dgbfTemp .Key = "City" .DataFieldName = "City" .DataType = "System.String" .DataFormatString = "" .Hidden = False .Width = Unit.Pixel(200) .Header.Text = "City" .Header.TemplateContainer.Controls.Add(lctlCity) End With wdgResults.Columns.Add(dgbfTemp) ' State Column 5 dgbfTemp = New Infragistics.Web.UI.GridControls.BoundDataField With dgbfTemp .Key = "State" .DataFieldName = "State" .DataType = "System.String" .DataFormatString = "" .Hidden = False .Width = Unit.Pixel(50) .Header.Text = "State" .Header.TemplateContainer.Controls.Add(lctlState) End With wdgResults.Columns.Add(dgbfTemp) ' Date of Birth Column 6 dgbfTemp = New Infragistics.Web.UI.GridControls.BoundDataField With dgbfTemp .Key = "DOB" .DataFieldName = "DOB" .DataType = "System.DateTime" .DataFormatString = "{0:MM/dd/yyyy}" .Hidden = False .Width = Unit.Pixel(100) .Header.Text = "DOB" .Header.TemplateContainer.Controls.Add(lctlDOB) End With wdgResults.Columns.Add(dgbfTemp) ' Designate Unsortable Columns Dim scs1 As New Infragistics.Web.UI.GridControls.SortingColumnSetting scs1.ColumnKey = "Select" scs1.Sortable = False wdgResults.Behaviors.Sorting.ColumnSettings.Add(scs1) End Sub Protected Sub Search(ByVal pSearchValue As String) marlDataRows = mblMS.Search(pSearchValue) ' Adjust Name For i As Integer = 0 To marlDataRows.Count - 1 marlDataRows(i).Employee() = LibFuncs.ConvertNameLFtoLF(marlDataRows(i).Employee()) Next wdgResults.DataSource = marlDataRows mblMS.SearchResults = marlDataRows MySession.MemberSearchObject = mblMS ' Save MemberSearch Object to Session End Sub Protected Sub SelectMember(ByVal sender As Object, ByVal e As System.Web.UI.WebControls.CommandEventArgs) Dim intSSN As Integer Dim blM As Member ' Determine selected row. If wdgResults.Behaviors.Selection.Index > -1 Then intSSN = Convert.ToInt32(wdgResults.Behaviors.Selection.SelectedRows.Item(0).Items(1).Value) Else ' Nothing selected GoTo Exit_SelectMember End If blM = New Member(MySession.cnnDB, MySession.DBSchema, MySession.DBSchema_Employer, MySession.DBSchema_Payroll) blM.GetMember(intSSN) MySession.MemberObject = blM MySession.AddRecallItem(LibFuncs.DisplaySSN(intSSN.ToString)) ' Save SSN. Select Case MySession.STS_InquiryPath Case InquiryPath.Pension Select Case True Case MySession.IsActiveFunction(Functions.SearchMember) If MySession.STS_EditMode = Constants.EditMode Then MySession.BeginFunction(Functions.EditMember) Else MySession.BeginFunction(Functions.ViewMember) End If Response.Redirect(Screens.MemberMaintenance, False) Case MySession.IsActiveFunction(Functions.SearchPensionHistory) If MySession.STS_EditMode = Constants.EditMode Then MySession.BeginFunction(Functions.EditPensionHistory) Else MySession.BeginFunction(Functions.ViewPensionHistory) End If Response.Redirect(Screens.PensionHistory, False) Case MySession.IsActiveFunction(Functions.SearchAdjudication) MySession.BeginFunction(Functions.PensionAdjudication) Response.Redirect(Screens.PensionSelect) End Select End SelectExit_SelectMember: Exit Sub End Sub Protected Sub addTrigger_PreRender(ByVal sender As Object, ByVal e As EventArgs) Dim btnSelect As LinkButton = TryCast(sender, LinkButton) Dim NewScriptManager As ScriptManager = DirectCast(Master.FindControl("ScriptManager1"), ScriptManager) NewScriptManager.RegisterPostBackControl(btnSelect) End Sub Private Sub ClearResults() marlDataRows.Clear() wdgResults.Rows.Clear() wdgResults.Behaviors.Paging.PageIndex = 0 wdgResults.Behaviors.Selection.SelectedRows.Clear() End Sub Protected Sub wdgResults_ColumnSorted(ByVal sender As Object, ByVal e As Infragistics.Web.UI.GridControls.SortingEventArgs) Handles wdgResults.ColumnSorted ResetPager() End Sub Protected Sub wdgResults_InitializeRow(ByVal sender As Object, ByVal e As Infragistics.Web.UI.GridControls.RowEventArgs) Handles wdgResults.InitializeRow ' Date of Birth If e.Row.Items(6).Value = "01/01/0001" Then e.Row.Items(6).Text = "" End If End Sub Protected Sub cmdSearch_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles cmdSearch.Click Dim strSearchValue As String strSearchValue = txtSearch.Text.Trim.ToUpper ClearResults() If strSearchValue.Trim.Length = 0 Then lblErrorMessage.Text = "A Name, Member ID Number or Social Security Number is required." lblErrorMessage.Visible = True Else lblErrorMessage.Visible = False If IsNumeric(Left(strSearchValue, 1)) Then strSearchValue = Replace(strSearchValue, "-", "") ' Remove dashes in the SSN if present. End If mblMS.SearchValue = strSearchValue ' 12/30/2009 - Remember Search Argument Search(strSearchValue) SetPagerInfo() End If End Sub Protected Sub cmdRecallNext_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles cmdRecallNext.Click ' Get Next Recall Item. txtSearch.Text = MySession.GetRecallItem End Sub Protected Sub cmdRecallPrev_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles cmdRecallPrev.Click ' Get Previous Recall Item. txtSearch.Text = MySession.GetRecallItem End Sub Protected Sub SetupRecallForPartialPostBack() Dim NewScriptManager As ScriptManager = DirectCast(Master.FindControl("ScriptManager1"), ScriptManager) NewScriptManager.RegisterAsyncPostBackControl(cmdRecallNext) NewScriptManager.RegisterAsyncPostBackControl(cmdRecallPrev) End Sub ' Pager Routines Private Sub SetPagerInfo() If marlDataRows.Count > wdgResults.Behaviors.Paging.PageSize Then Me.wdgResults.Behaviors.Paging.Enabled = True Me._customPager.SetContext(marlDataRows.Count, wdgResults.Behaviors.Paging.PageSize) Else Me.wdgResults.Behaviors.Paging.Enabled = False End If End Sub Private Sub _customPager_PageChanged(ByVal sender As Object, ByVal e As PageSettingsChangedEventArgs) If (e.TotalNumberOfPages - 1) < e.PageIndex Then Me.wdgResults.Behaviors.Paging.PageIndex = 0 Else Me.wdgResults.Behaviors.Paging.PageIndex = e.PageIndex End If End Sub Protected Sub ResetPager() wdgResults.Behaviors.Paging.PageIndex = 0 SetPagerInfo() End SubEnd Class
Hello Anna,
I will need some time to investigate your query. I will update you with my progress as soon as possible.
While trying to replicate the behavior on my side I tried creating working sample with the provided source code (having a working sample is the best approach for finding the root cause of the behavior). However, there are a lot of missing components (Does the Search method of MemberSearch class return data? ), which prevents me from running the sample. Can you please modify the sample I started so that it replicates the issue on your side?
Having a working sample on my side is going to be highly appreciated and will help me find the root cause of the behavior.
8713.Sample.zip
Hi Martin,
Thank you for the reply. We figured out the problem so there is no need to replicate the issue.
Anna Schwab
Hi Anna,
I am glad that you have resolved your issue.
