2680
WebDataTree adding nodes server side
I am manually adding nodes to a WebDataTree with code similar to that below - I'm used to the old UltraWebTree so perhaps I can't do this way but it seems logical...
Dim rootNode As DataTreeNode = tvFormContent.Nodes.Add(_form.Name)
' Get a list of categories defined for this form
For Each category As MobileFormCategory In _form.Categories
Dim categoryNode As DataTreeNode = rootNode.Nodes.Add(category.Name)
' Any questions within this category?
Dim formQuestions As List(Of MobileFormQuestion) = category.Questions
For Each question As MobileFormQuestion In category.Questions
Dim questionHeading As String = question.Heading & " " & "[" & question.DataTypeAsString & "]"
Dim questionNode As DataTreeNode = categoryNode.Nodes.Add(questionHeading)
Next
Next
The nodes are added to the tree and I can expand them however if I have multiple items at the same level they are displayed horizontally and not vertically as I would expect...
  • 80
    Hello Chris,
    After investigating this further, I determined that the nodes are probably displayed horizontally due to missing styles. You could check the Web.config for the following line:
    <infragistics.web enableAppStyling="true" styleSetName="Default" styleSetPath="~/ig_res" />
    You could also specify the styleName and stylePath in the WebDataTree tag as follows:
    <ig:WebDataTree ID="WebDataTree1" runat="server" Height="300px" Width="200px" StyleSetName="Default" StyleSetPath="~/ig_res">
    Alternatively,  you could try adding nodes similarly to this way:
    Dim numbers = New Integer() {1, 2, 4, 8}
            For Each ctr As Integer In numbers
                Dim newFeed As New Infragistics.Web.UI.NavigationControls.DataTreeNode()
                newFeed.Text = ctr
                newFeed.Text = ctr
                WebDataTree1.Nodes.Add(newFeed)
            Next
    If the nodes are still displayed horizontally could you please provide me a small isolated sample that replicates the issue.
    Monika Kirkova,
