85
Refresh WebDataGrid
I have these 2 functions that open a WebDialogWindow from a WebDataGrid.
Client side
function WebDataGrid1_DblClickHandler(sender, e) {
      var grid = $find('<%= WebDataGrid1%>');
      var gridBehaviors = grid.get_behaviors();
      var row = gridBehaviors.get_selection().get_selectedRows().getItem(0);
      var rowId = row.get_dataKey()
      var dialog = $find('<%= WDWIns.ClientID %>');
      dialog.get_contentPane().set_contentUrl('management.aspx?key=' + rowId);
      dialog.set_windowState($IG.DialogWindowState.Normal);
Server side
Private Sub WebDataGrid1_ItemCommand(sender As Object, e As HandleCommandEventArgs) Handles WebDataGrid1.ItemCommand
      Dim commandArgument As Object = e.CommandArgument
      Dim key As String = commandArgument.ToString
      Dim url As String = "management.aspx?key=" + key
      WDWIns.ContentPane.ContentUrl = url
      WDWIns.WindowState = Infragistics.Web.UI.LayoutControls.DialogWindowState.Normal
End Sub
When the user is done making changes to the data on the WebDialogWindow I close the window using this function.
function closeDialogs() {
     var win = window.parent;
     var dialog = win.$find('WDWIns');
     if (dialog) {
         dialog.hide();
Becasuse the user has made changes to the data, I need to refresh the WebDataGrid. How can I do that?
Thanks, Pat
Top Replies
