15
WebDataGrid with Selenium
I am trying to use C# and Selenium to read a page.using webDataGrid
The WebDataGrid in the page is defined as follows
<iggc:webdatagrid Id="grdAccountList" runat="server" AutoGenerateColumns="False" DataKeyFields="RowSequenceIndex">
   <columns>
    <iggc:BoundDataField key="ActPercent" DataFieldName ="ActPercent" Header-Text="Percent" DataType="System.Decimal" DataFormatString="{0:n2}" > </iggc:BoundDataField>
   </Columns>
<EditorProviders>
  <iggc:NumericEditorProvider ID="PercentProviderId">
   <EditorControl MaxDecimalPlaces="2" MaxValue="100" MinValue = "0"
<i/ggc:NumericEditorProvider >
</EditorProviders>
<Behaviors>
<iggc:Activation Enabled="true"></iggc:Activation>
<iggc:Selection CellClickAction="Row" RowSelectType="Single" Enabled="true"> </iggc:Selection>
<iggc:RowSelectors Enabled="true" RowNumbering="true"> </iggc:RowSelectors>
<iggc:EditingCore AutoCrud="false" Enabled="true"> </iggc:EditingCore>
<Behaviors>
<iggcLCellEditing Enabled="true" EditModeActions-MouseClick="Single" EditModeActions-EnableOnActive="true">
<ColumnSettings>
<iggc:EditingColumnSetting columnkey="ActPercent" EditorId="PercentProviderId">
</ColumnSettings>
</iggc:CellEditing>
</Behaviors>
</iggc:WebDataGrid>
The C# Selenium code is as follows
IJavaScriptExecutor js = (IJavaScriptExecutor)driver;
string js2 = "document.getElementById('grdAccountList').get_cell().get_index().set_Value(20);
js.Execute.Script(js2);
When I run the Selenium code , if fails with error "get_cell() function not found"
