1000
WebDialogWindow not shown through server side
I doesn't seem to get it to work. I used parts of your example to see if it could manage it.
Protected Sub btnShow_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles btnShow.Click
        Select Case WebDialogMsg.WindowState
            Case Infragistics.Web.UI.LayoutControls.DialogWindowState.Hidden
                WebDialogMsg.WindowState = Infragistics.Web.UI.LayoutControls.DialogWindowState.Normal
        End Select
 End Sub
<ig:WebDialogWindow ID="WebDialogMsg" runat="server" Height="120px" Width="400px" InitialLocation="Centered" Modal="True" Style="display:none;" StyleSetName="Claymation" StyleSetPath="~/ig_res" WindowState="Hidden">
            <Header CaptionText="Aviso">
            </Header>
            <ContentPane>
            <Template>
                <table cellpadding="4" cellspacing="4" border="0" class="modalInfragistics">
                <tr><td><asp:Label ID="lblAvisoMessage" runat="server" Text="" Font-Bold="true"></asp:Label></td></tr>
                </table>
                <table style="margin-left:auto;margin-right:auto;">
                <tr>
                    <td>
                        <table cellpadding="2" cellspacing="0" border="0" class="TableButtonOut" onmouseover="this.className = 'TableButtonOver';" onmouseout="this.className = 'TableButtonOut';" onclick="$find('<%= WebDialogMsg.ClientID %>').hide();return false;">
                        <tr>
                            <td align="center" valign="middle"><img id="Img7" src="~/Images/acceptar.png" runat="server" alt="" /></td>
                            <td align="center" valign="middle">OK&nbsp;&nbsp;&nbsp;</td>
                        </tr>
                        </table>
                    </td>
                </tr>
                </table>
            </Template>
            </ContentPane>
        </ig:WebDialogWindow>
  <asp:Button ID="btnShow" runat="server" Text="Show" />
When I use breakpoints it is definitly changing the WindowState, but the result remains, no modal dialog window. Any clues?
I forgot to tell you that I am using I am using asp.net 2.0 infragistics controls 2008 vol 3
