165
In the next version of the component, if these codes would be add?
I found that the javascript's operation of ajax may be error if  the client can't connect to the server.
To support the code stronger,this "try...catch" code should be add.
In the ig_shared.js(Version 7.3.20073.38)
line:1306
this code:
this.execute = function ()
        var exec = true;
        if(this.beforeCallback != null)
                exec = this.beforeCallback();
        if(exec && this._xmlHttpRequest)
                if(this._progressIndicator != null)
                    this._progressIndicator.display();
                this.formatCallbackArguments();
                this.registerSmartCallback();
                this._xmlHttpRequest.open("POST", this.getUrl(), !this._waitResponse);
                this._xmlHttpRequest.setRequestHeader("Content-Type", "application/x-www-form-urlencoded");
                this._xmlHttpRequest.onreadystatechange = this._responseComplete;
                this._xmlHttpRequest.send(this.getCallbackArguments());
should be changed:
        var exec = true;
            try                 // code add
            }catch(e){}         // code add
Thanks.
Parents
No Data
Reply Children
