I was quite disappointed when I found out that the [WebHierarchicalDataGrid] component didn't use the same StyleSet assignment syntax as the rest of your .NET controls (Please correct me if I'm wrong btw - but trying the usual [EnableAppStyling=True and StyleSetName="" properties in the *.aspx] didn't work.
In any case, I eventually found your example page that describes the way to assign a StyleSet [here - http://labs.infragistics.com/aspnetctp/Samples/WebHierarchicalDataGrid/WebHierarchicalDataGrid_BandStyling.aspx?View=Run].
Unfortunately, we're a VB.NET shop and your StyleSet example is C# only. We've done some initial C#-to-VB translation but so far we can't get the example working.
So - could you please create a VB code example of this page?
Thank you
Setting StyleSetName in the aspx worked out for me. Please make sure that the style set you're trying to set is present in the local ig_res folder.
It's possible that we fixed something along the way though.
ig:WebHierarchicalDataGrid StyleSetName="Appletini" ID="WebHierarchicalDataGrid1" Width="655px"
This particular sample shows how to assign different styles to the subgrids. The approach should not be needed to style the control in general.
Chris,
Sorry to hear that you are having trouble with one of the samples. The sample you referenced is for styling RowIslands differently within the same WHDG. I converted the sample to VB and it is working for me. Here is a snippet of code for your reference.
Protected Sub RowIslandCreated(ByVal sender As Object, ByVal e As Infragistics.Web.UI.GridControls.RowIslandEventArgs) Handles whdg1.RowIslandCreated
If (e.RowIsland.Key.Equals("Details")) Then
e.RowIsland.StyleSetName = "Trendy"
ElseIf (e.RowIsland.Key.Equals("Shippers")) Then
e.RowIsland.StyleSetName = "Claymation"
End If
End Sub
Please let us know if you continue to have problems.
Ed CerboneInfragistics Experience Design Group
i find this post about this control very interesting sent by u
i am Arti working in ASP.net 3.5
But i wanted to know from that start to end about how can i use this webHierarchicalDataGrid in c# only
please let me know
what extra i have to download for this control and how in can use it in .aspx and .cs page in c# only
Waiting for yor response
Arti,Did you take a look @ our online samples? If you go to https://www.infragistics.com/samples/aspnet/hierarchical-data-grid/overview there is a collections of samples for the WebHierarchicalDataGrid. If you would still like to download and run something locally you can go to https://www.infragistics.com/products/aspnet to download the product. Let me know if I can help you further.
Ed
hi
i have downloaded the Software
but how to use this ajax controls in my web application
means how this controls wil be available in my .aspx pages
do i hv to do any reference to my application
