15
Problem with 2 recurring appointments
Hi, I'm working on a custom web schedule provider.  This system has appointments and recurring appointments.  The problem I'm having is that if I have 2 recurring appointments in a month and they do not overlap, the monthly calendar shows the dates between as bold and if I look at one of those dates it has the first recurring appointment in it.  For example, I have one appoint from 1/5 - 1/13 and another from 1/19 - 1/27.  It looks as if the first appointment goes until 1/27.
I'm currently running on v7.1, but I've also tested on 2009 vol 2 with the same result.
The following is a snippet of the current code (I've been modifying it a lot so this might not be the best try, but they all seem to have the same result).  I've also attached a screen shot to show what I am seeing.  Thanks for any help at all!
Mike Witt
        private const string recurAppointmentKey = "RecurrenceAppointmentList";
        private List<Appointment> appointmentList;
        /// <summary>
/// Fetches WebSchedule objects from the underlying data source.
/// </summary>
/// <param name="context">A DataContext subclass containing parameter values for use when carrying out a fetch operation.</param>
public void Fetch(DataContext context)
// Take action based on the operation provided
            try
                switch (context.Operation)
                    case "FetchActivities":
                        if (HttpContext.Current.Session[recurAppointmentKey] != null) HttpContext.Current.Session.Remove(recurAppointmentKey);
                        appointmentList = new List<Appointment>();
                        FetchActivities((FetchActivitiesContext)context);
                        if (appointmentList.Count > 0) HttpContext.Current.Session.Add(recurAppointmentKey, appointmentList);
                        break;
                    case "FetchRecurrences":
                        FetchRecurrences((FetchRecurrencesContext)context);
                        break;
            finally
                if (context.Operation == "FetchRecurrences" && HttpContext.Current.Session[recurAppointmentKey] != null) HttpContext.Current.Session.Remove(recurAppointmentKey);
/// <summary>
/// Selects activities from the WebSchedule data store by date range and organizer.
/// </summary>
/// <param name="context">Describes the <see cref="Activities"/> being selected, in particular,
/// their organizing resource and date range of interest.</param>
private void FetchActivities(FetchActivitiesContext context)
// Clear any existing activities
context.Activities.Clear();
            //Recurrence recurrence ;
// get the trips
// REMOVED DATA ACCESS FOR SIMPLICITY OF SAMPLE - fetched the "employees" list.
foreach (Trip_EmployeeSchedule employee in employees)
// Create a new Appointment with a reference to the ScheduleInfo object that requested the fetch
Appointment appointment = new Appointment(this.WebScheduleInfo);
// Configure the Appointment with the information in the data source
                appointment.Key = employee.RecordID.ToString();
                appointment.Subject = employee.Subject;
                appointment.Description = employee.Description;
                //appointment.RecurrenceKey = employee.Recurrence;
                appointment.StartDateTime = new SmartDate(employee.StartDateTime);
                appointment.EndDateTime = new SmartDate(employee.EndDateTime);
appointment.EnableReminder = false;
                appointment.ShowTimeAs = ShowTimeAs.OutofOffice;
                appointment.RecurrenceKey = employee.RecordID.ToString() + " " + appointment.Subject;
                if (employee.Recurrence == "Y") appointmentList.Add(appointment);
                // Add the Appointment to the Activities list in the context
                ((IList)context.Activities).Add(appointment);
            Trip_TripDriverVehicleService DriverVehicleServ = new Trip_TripDriverVehicleService();
            DataSet dsTripInfo = DriverVehicleServ.GetTripItemsForSechedule(this.EmployeeID, startDate, endDate);
            int iKey = 0;
            foreach (DataRow drAppointment in dsTripInfo.Tables[0].Rows)
                iKey = (int)drAppointment["RecordID"];
                iKey = -iKey;
                appointment.Key = iKey.ToString();
                appointment.Subject = drAppointment["TripName"].ToString();
                appointment.Description = string.Empty;
                appointment.StartDateTime = new SmartDate(Convert.ToDateTime(drAppointment["OriginDepartureTime"]));
                appointment.EndDateTime = new SmartDate(Convert.ToDateTime(drAppointment["OriginReturnTime"]));
                appointment.ShowTimeAs = ShowTimeAs.Busy;
        private void FetchRecurrences(FetchRecurrencesContext context)
            //context.Activities.Clear();
            context.Recurrences.Clear();
            // get the trips
                if (employee.RecurrencePeriod != null)
                    string recurrenceKey = employee.RecordID.ToString() + " " + employee.Subject;
                    // Find the appointment from the cache
                    Appointment myAppt = null;
                    foreach (Appointment appt in appointmentList)
                        if (appt.RecurrenceKey == recurrenceKey)
                            myAppt = appt;
                            break;
                    if (myAppt == null) continue;
                    myAppt.CreateRecurrence();
                    Recurrence recurrence = myAppt.Recurrence;
                    recurrence.Key = recurrenceKey;
                    if (employee.RecurrencePeriod == Convert.ToInt32(TripTrackerUtilities.ScheduleEnumerations.RecurrencePeriod.Daily))
                        recurrence.Period = Infragistics.WebUI.WebSchedule.RecurrencePeriod.Daily;
                    else if (employee.RecurrencePeriod == Convert.ToInt32(TripTrackerUtilities.ScheduleEnumerations.RecurrencePeriod.Weekly))
                        recurrence.Period = Infragistics.WebUI.WebSchedule.RecurrencePeriod.Weekly;
                    else if (employee.RecurrencePeriod == Convert.ToInt32(TripTrackerUtilities.ScheduleEnumerations.RecurrencePeriod.Monthly))
                        recurrence.Period = Infragistics.WebUI.WebSchedule.RecurrencePeriod.Monthly;
                        if (employee.RecurrenceDay.HasValue)
                            recurrence.DayOfMonth = (int)employee.RecurrenceDay;
                        recurrence.Period = Infragistics.WebUI.WebSchedule.RecurrencePeriod.Yearly;
                    else if (employee.RecurrencePeriod == Convert.ToInt32(TripTrackerUtilities.ScheduleEnumerations.RecurrencePeriod.EveryWeekday))
                        recurrence.DayOfWeekMaskUtc = RecurrenceDayOfWeekMask.AllWeekdays;
                    if (employee.RecurrencePeriodMultiple.HasValue)
                        recurrence.PeriodMultiple = (int)employee.RecurrencePeriodMultiple;
                    if (employee.RecurrenceEndDate.HasValue)
                        recurrence.EndDateUtc.Value = (DateTime)employee.RecurrenceEndDate;
                    else
                        recurrence.EndDateUtc.Value = DateTime.Today.AddYears(2);
                    ((IList)context.Recurrences).Add(recurrence);
