185
Server-Side Events from WebDataMenu
I am trying to create an application and use the WebDataMenu control. However, I've noticed that there are no server-side events to hook (that I can see) and when using client-side javascript to access the item (per this article), it always returns the key of the first item.
So, how do I capture server-side events that will allow me to tell which menu item was clicked?
Parents
No Data
Reply
  • 185
    Verified Answer
    Actually, I was able to figure this out myself. I did it using the following in the code-behind page.
    1. Add the event handler to the Page_Load.
    this.WebDataMenu1.ItemClick += new Infragistics.Web.UI.NavigationControls.DataMenuItemEventHandler(WebDataMenu1_ItemClick);
    2. Add the ItemClick event to be triggered on click, as specified in the event handler.
    protected void WebDataMenu1_ItemClick(object sender, Infragistics.Web.UI.NavigationControls.DataMenuItemEventArgs e)
    switch (e.Item.Key)
    case "Item1":
                   Response.Write(
    "Item1 was clicked.");
    break;
    case "Item2":
                   Response.Write(
    "Item2 was clicked.");
    break;
    case "Item3":
                   Response.Write(
    "Item3 was clicked.");
    break;
    case "Item4":
                   Response.Write(
    "Item4 was clicked.");
    break;
    default:
                   Response.Write(
    "No item clicked");
    break;
Children
No Data
