435
Controls array is empty in template?
I have a WebExplorerBar I am attempting to use as a replacement for WebPanel.  I'm adding a control template and trying to bind to a ul list.  I have javascript that will "scroll" through the UL showing one item at a time.  The problem is, when i try to access the ListView item in the template, FindControl is returning null.  If i look at the ControlCollection object in the template, (either via FindTemplateByID or Templates[0] of the explorer) it comes back with 0 items.  What am i doing wrong?
    <ig:WebExplorerBar runat="server" ID="NewsExplorer" Width="100%">
        <Groups>
            <ig:ExplorerBarGroup Text="News and Headlines">
                <Items>
                    <ig:ExplorerBarItem TemplateId="NewsItem">
                    </ig:ExplorerBarItem>
                </Items>
            </ig:ExplorerBarGroup>
        </Groups>
        <Templates>
            <ig:ItemTemplate TemplateID="NewsItem">
                <Template>
                    <asp:ListView ID="HeadlineFader" runat="server" EnableViewState="false">
                        <LayoutTemplate>
                            <ul id="newsfade">
                                <asp:PlaceHolder ID="itemPlaceholder" runat="server" />
                            </ul>
                        </LayoutTemplate>
                        <ItemTemplate>
                            <li class="newsitems">
                                <asp:HyperLink ID="NewsLink" runat="server" NavigateUrl="#" rel='<%# "#NEWS" + Eval("ID") %>' title='<%#Eval("TEXT") %>' Text='<%# Eval("TITLE")%>' />
                            </li>
                        </ItemTemplate>
                    </asp:ListView>
                </Template>
            </ig:ItemTemplate>
        </Templates>
    </ig:WebExplorerBar>
(CodeBehind)
        ItemTemplate temp = this.NewsExplorer.FindTemplateById("NewsItem");
        ListView HeadlineFader = temp.FindControl("HeadlineFader") as ListView;
        HeadlineFader.DataSource = NewsData.GetNews();
        HeadlineFader.DataBind();
Parents
  • 3726
    Suggested Answer
    the correct lookup of the template is:
    this.NewsExplorer.Groups[0].Items[0].FindControl("HeadlineFader");
    What's in the code of the sample will obviously not work, since it's trying to obtain an instance of the ListView, from the template definition object, not from a specific instantiation of it, for some WebExplorerBar item.
    Lubomir
Reply Children
No Data
