I have a WebTab control with two Tabs. Each tab has a ContentTabItem that contains a number of controls, such as textboxes.
I need to be able to hide one of the tabs on Page-load depending on values returned from the database. I have tried using the Hidden property so that one tab is hidden and the other is not, however, despite extensive testing I am not able to make the webtab behave as I want. I have tried setting EnableLoad OnDemand but that does not resolve the issue.
What happens is that the first tab plus its ContenttabItem display ok, but when I try to look at the second tab only, the tab page is visible but the ContenttabItem is not.
can anyone help?
Hello dweir74,
Could you upload your sample here please, steps to reproduce will be needed too.
Hi Rado,
No need, I've sorted the problem myself. It just needed the right combination of Hidden and SelectedIndex properties.
Regards
