600
WebDataGrid - Evaluating fields inside of a TemplateDataField
I have a WebDataGrid which has a column I've defined as a TemplateDataField.
In that field, I want to display data conditionally depending on the values of Field1 and Field 2
Field1 always has data, so I display it as follows:
<ig:TemplateDataField Key="ContactPersons">
<ItemTemplate>
  <%# DataBinder.Eval(CType(Container, Infragistics.Web.UI.TemplateContainer).DataItem, "Field1")%>
 </ItemTemplate>
</ig:TemplateDataField>
However, I first need to test the contents of Field2 to determine if I want to display it as well in that same column.
I'm wanting to use something similar to this:
 <ItemTemplate>
       Dim strField2 As String
       strField2 = DataBinder.Eval(CType(Container, Infragistics.Web.UI.TemplateContainer).DataItem, "Field2")
       if strField2 <> "" then
             'Code for displaying Field2 here
       end if
 </ItemTemplate>
The strField2= line above does not work because that's the wrong syntax.
My question is how do I retrieve data elements inside of an ItemTemplate so that I can evaluate them and add conditional logic?  How do I retrieve the value of Field2 so I can evaluate it?
strField2 = ????
John
  • 6748
    Verified Answer
    Hello John,
    You can create a protected function in your code-behind that will perform the checks that you would like:
    Protected Function ComputeField(ByRef field1 As Object, ByRef field2 As Object) As String
            If field2 <> "" Then
            End If
            Return strField2
        End Function
    And then you can call it inside the item template:
    <%# ComputeField(DataBinder.Eval(CType(Container, Infragistics.Web.UI.TemplateContainer).DataItem, "Field1"), DataBinder.Eval(CType(Container, Infragistics.Web.UI.TemplateContainer).DataItem, "Field2"))%>
    Hope this helps.
    Lyuba
    Developer Support Engineer
    www.infragistics.com/support
