60
ultrawebtab on mouseover
hii
i want do show content of ultrawebtab on mouseover on tab instead of click...whwnever i put  mouse
pointer on tab content should display....
i got clicent side enet mouseover...but when i tried it doesn't give result what i want ...
please give me solution .....
  • 24497
    That is quite easy to do: eventArgs has member method get_tabIndex(). However, you should keep in mind that changing selected index on mouseover/move may lead to unexpected behavior, especially if loadOnDemand/ajax is enabled or tabs have large contents. Below is example for you:
    function WebTab1_MouseOver(sender, eventArgs)
     var tab = eventArgs.get_tabIndex();
     if (tab >= 0 && tab != sender.get_selectedIndex())
      sender.set_selectedIndex(tab);
    </script>
        <ig:WebTab ID="WebTab1" runat="server" Width="300px" Height="300px">
       <Tabs>
        <ig:ContentTabItem runat="server" Text="Tab 1">
        </ig:ContentTabItem>
        <ig:ContentTabItem runat="server" Text="Tab 2">
        <ig:ContentTabItem runat="server" Text="Tab 3">
       </Tabs>
       <ClientEvents MouseOver="WebTab1_MouseOver" />
      </ig:WebTab>
