Hi, i hope, any could help me
In my primary page I have a User Control embedded, inside of an UpdatePanel, this user control shows a WebDataGrid, some filters and a "Search" button.
This WebDataGrid, which is inside another UpdatePanel, has a pager, Now..
When i click the "Search" Button, the grid fills perfect but when PageIndexChanged event fires, the grid set to blank and that's it.
Right after that, if i click the "Search" Button again, the Grid fills with the Data, and pointing to the new Page Index.
My problem is... why it goes blank on the PageIndexChanged event?
Plz help, i'm on a hurry!
If you need some code, i can provide it
Thanks in advance
I am not sure what can be the issue at this point, but I would suggest make sure that the following things are true:
Datasource is assigned to the grid on each postback and since you are use UpdatePanels set EnableAJAX to false.
Hope this helps
Did you ever find a solution to this? I'm seeing the same behavior.
Can you attach your code here, please.
Did you find a solution for this ? How do I bound data to the page that user selected ?
