Has anyone else had issues using a WebDatePicker inside a Master Page ?
When I place a WebDatePicker on a regular WebForm, it works just fine. But when I put it on a WebForm that is using a Master Page ... when I click on the control it does not popup the calendar or do anything.
I'm using Version 2010.3.
Thanks,John
I am using 9.2 SR2.
No problems on this end..
Are your pages ajax enabled?
Hello John,
Would you attach a sample application with which we can replicate your issue?
Lyuba
Developer Support Engineer
www.infragistics.com/support
Lyuba:I'll have to spend a little time putting together a simple example of this not working. The issue I'm having is with a Master Page that is part of a Department of Defense application -- so I can't share that exact example in this forum.
My question was mainly directed at whether or not others have also experienced the WebDataPicker not working inside of a Master Page. So far, nobody has said they have ... so it could be something code related in my application or possibly a configuration problem when I upgraded the Project from 2010.2 to 2010.3.
I have created a support ticket on your behalf in order to investigate this issue further.
Hi, i'm having exactly the same issue. Any solution?
Thank you.
