I am new to infragistics control,i am working on asp.net website,whenever i run my website on google chrome and if the users session is expired then sorting the columns or performing any operation on infragistic grid fetch an error .'Deserialization failure,Invalid response '
Could any one send me the code how to catch this error.
I want to redirect a user to login page without facing that error.
Kindly Help!!!!
this is solved by using EnableAjax="false" in <ig:WebDataGrid ID="webTableGrid" >
did you try it with sorting columns ? since I cant sort them with ajax on.off
my post
https://www.infragistics.com/community/forums/f/ultimate-ui-for-asp-net/51005/column-sorting-error
yes i am able to sort column,resize column and drag and drop functionality.
Could you explain what type of error you are getting after ajax off.
pls post your code.....
Error i'm getting after pressing on sort
DotNetNuke.Services.Exceptions.PageLoadException: Kan geen voorlooptekens (..) gebruiken voor afsluiten boven de hoogste map. ---> System.Web.HttpException: Kan geen voorlooptekens (..) gebruiken voor afsluiten boven de hoogste map. bij System.Web.Util.UrlPath.ReduceVirtualPath(String path) bij System.Web.Util.UrlPath.Reduce(String path) bij System.Web.UI.Control.ResolveClientUrl(String relativeUrl) bij Infragistics.Web.UI.GridControls.Sorting.AddHeaderImgToCaption(GridField column, SortDirection direction) bij Infragistics.Web.UI.GridControls.Sorting.BehaviorEvents_PreRender(Object sender) bij Infragistics.Web.UI.GridControls.GridRenderer.RenderContents(HtmlTextWriter writer) bij Infragistics.Web.UI.Framework.RunBot.HandleRenderContents(HtmlTextWriter writer, RendererBase renderer) bij Infragistics.Web.UI.Framework.Data.FlatDataBoundControl.Render(HtmlTextWriter writer) bij ASP.desktopmodules_autorisatie_autorisatie_view_ascx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) bij System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) bij System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) bij DotNetNuke.UI.Modules.ModuleHost.RenderContents(HtmlTextWriter writer) bij System.Web.UI.WebControls.WebControl.Render(HtmlTextWriter writer) bij System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) bij System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) bij System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) bij System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) bij System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) bij System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) bij System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) bij System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) bij System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) bij System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) bij System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) bij System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) bij ASP.default_aspx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) bij System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) bij System.Web.UI.Page.Render(HtmlTextWriter writer) bij System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) --- Einde van intern uitzonderingsstackpad ---
My vb code for sorting:
Protected Sub WebDataGrid1_ColumnSorted(ByVal sender As Object, ByVal e As Infragistics.Web.UI.GridControls.SortingEventArgs) Handles WebDataGrid1.ColumnSorted If e.Column.Key = "Username" Then Dim dir As Infragistics.Web.UI.SortDirection = e.SortedColumns(e.Column.Key).SortDirection e.SortedColumns.Add("Username", dir) e.SortedColumns.Add(e.Column.Key, dir) End If End Sub
My Asp Code:
<ig:WebDataGrid ID="WebDataGrid1" runat="server" AutoGenerateColumns="False" Height="350px" Width="697px" style="margin-bottom: 4px" EnableAjax="False"> <Columns>
<%-- COLUMN USER_ID--%> <ig:BoundDataField DataFieldName="UserID" Key="UserID" Hidden="True" Width="50px"> <Header Text="UserID" /> </ig:BoundDataField>
</Columns> <Behaviors> <ig:ColumnResizing> </ig:ColumnResizing> <ig:Sorting SortingMode="single" Enabled="true" EnableInheritance="True"> <ColumnSettings> <ig:SortingColumnSetting ColumnKey="Username" /> </ColumnSettings> </ig:Sorting> </Behaviors> </ig:WebDataGrid>
