70
Adding a context menu to the tabs
Just thought that I'd share a solution with everyone.
I have a requirement to be able to trap the oncontextmenu event of the tab headers.  As there doesn't seem to be any intrinsic way of handling this I came up with the following solution:
1. On the client-side, after the tab object has been instantiated: iterate each Tab object instance and add a oncontextmenu event handler to the element of each tab:
/// <summary>
/// Adds a context menu handler to each of the individual tab header elements for a tab control.  The handler
/// should conform to the following method signature: handler(tabKey).
/// <summary>
/// <author>Kevin White</author>
/// <date>01/06/2011</date>
/// <example>igtab_initialiseContextMenuHandlers('tabClientID', 'displayMenu(tabKey);');</example>
function igtab_initialiseContextMenuHandlers(tabsClientId, handler) {
    var tabs = igtab_getTabById(tabsClientId);
    if (tabs !== null) {
        Array.forEach               // Requires the Microsoft AJAX framework but otherwise just change to a conventional loop
                tabs.Tabs
                , function(tab, tabIndex, allTabs) {
                    // Add an 'oncontextmenu' handler to each of the tab headers by attaching a function handler to the element (which is a TD element)
                    tab.element.oncontextmenu = function() { new Function("tabKey", handler)(tab.Key); return false; };
                , null
2. Add a call to igtab_initialiseContextMenuHandlers from the server-side (I plan to derive my own class to do this):
            string ss = "Sys.Application.add_load(function() { igtab_initialiseContextMenuHandlers('" + TopicTopLevelTabs.ClientID + "', 'do_click_test(a);'); });";
            ScriptManager.RegisterStartupScript(this, this.GetType(), new Guid().ToString(), ss, true);
Note that step 2 is dependent on the Microsoft AJAX framework.
Hope this helps someone!
