How to a bind Record to webgrid in button click event with sorting,paging,filtering,Grouping,Editing with code base..
Thanks in Advance
Karthik
Hello karthi2itnet,
The below markup and code behind will give more idea on how to bind grid on button click and on subsequent Ajax post back:
HTML Mark up:
<asp:ScriptManager ID="ScriptManager1" runat="server"></asp:ScriptManager><ig:WebDataGrid ID="WebDataGrid1" runat="server" Height="350px" Width="400px"></ig:WebDataGrid><asp:Button ID="Button1" runat="server" Text="Bind Data" onclick="Button1_Click" />
Code:
protected void Page_Load(object sender, EventArgs e){this.WebDataGrid1.DataSource = Session["data"];}protected DataTable getdata(){DataTable dt = new DataTable("Cutomer");dt.Columns.Add("ID", typeof(int));for (int i = 0; i < 10; i++){dt.Rows.Add(i);}return dt;}protected void Button1_Click(object sender, EventArgs e){if (Session["data"] == null){Session["data"] = getdata();}Setbehavior();this.WebDataGrid1.DataSource = Session["data"];}private void Setbehavior(){WebDataGrid1.Behaviors.CreateBehavior<Infragistics.Web.UI.GridControls.Sorting>();WebDataGrid1.Behaviors.CreateBehavior<Infragistics.Web.UI.GridControls.Paging>();WebDataGrid1.Behaviors.Paging.PageSize =5;WebDataGrid1.Behaviors.Paging.PagerMode = Infragistics.Web.UI.GridControls.PagerMode.NumericFirstLast;WebDataGrid1.Behaviors.CreateBehavior<Infragistics.Web.UI.GridControls.EditingCore>();WebDataGrid1.Behaviors.EditingCore.Behaviors.CreateBehavior<Infragistics.Web.UI.GridControls.CellEditing>();WebDataGrid1.Behaviors.EditingCore.Behaviors.CellEditing.EditModeActions.MouseClick = Infragistics.Web.UI.GridControls.EditMouseClickAction.Single;}
For further details on how to add behavior at runtime please review relevant links from the link below:
<http://help.infragistics.com/NetAdvantage/ASPNET/2011.2/CLR4.0/?page=WebDataGrid_Behaviors.html>
I hope this helps.
I am just following up to see, if you were able to bind grid with behavior based on the information I have provided above.
Update me if you have any further questions with this matter.
